Datasheet ADA4930-1/ADA4930-2 (Analog Devices) - 2
DescriptionUltralow Noise Drivers for Low Voltage ADCs
Pages / Page25 / 2 — ADA4930-1/ADA4930-2. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. …
RevisionD
File Format / SizePDF / 633 Kb
ADA4930-1/ADA4930-2. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 5/2017—Rev. B to Rev. C. 1/2015—Rev. A to Rev. B
ADA4930-1/ADA4930-2 Data Sheet TABLE OF CONTENTS REVISION HISTORY 5/2017—Rev B to Rev C 1/2015—Rev A to Rev B
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 4 link to page 4 link to page 5 link to page 6 link to page 6 link to page 7 link to page 7 link to page 7 link to page 7 link to page 8 link to page 9 link to page 15 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19 link to page 23 link to page 24 link to page 25 link to page 25
Features .. 1 Test Circuits ... 15 Applications ... 1 Operational Description .. 16 General Description ... 1 Definition of Terms .. 16 Functional Block Diagrams ... 1 Theory of Operation .. 17 Revision History ... 2 Analyzing an Application Circuit .. 17 Specifications ... 3 Setting the Closed-Loop Gain .. 17 3.3 V Operation .. 3 Estimating the Output Noise Voltage .. 17 3.3 V V Impact of Mismatches in the Feedback Networks ... 18 OCM to VO, cm Performance ... 4 3.3 V General Performance ... 4 Input Common-Mode Voltage Range ... 18 5 V Operation ... 5 Minimum RG Value .. 19 5 V V Setting the Output Common-Mode Voltage .. 19 OCM to VO, cm Performance .. 6 5 V General Performance .. 6 Calculating the Input Impedance for an Application Circuit ... 19 Absolute Maximum Ratings .. 7 Layout, Grounding, and Bypassing .. 23 Thermal Resistance .. 7 High Performance ADC Driving ... 24 Maximum Power Dissipation ... 7 Outline Dimensions ... 25 ESD Caution .. 7 Ordering Guide .. 25 Pin Configurations and Function Descriptions ... 8 Typical Performance Characteristics ... 9
REVISION HISTORY 5/2017—Rev. B to Rev. C 1/2015—Rev. A to Rev. B
Changes to Figure 5 and Figure 6 ... 8 Updated Outline Dimensions ... 25 Changes to Input Common-Mode Adjustment with DC Biased Changes to Ordering Guide .. 25 Source Section .. 21 Changes to High Performance ADC Driving Section
10/2010—Rev. 0 to Rev. A
and Figure 60 .. 24 Changes to General Description Section ... 1 Updated Outline Dimensions ... 25 Changes to Ordering Guide .. 25
10/2010—Revision 0: Initial Version
Rev. C | Page 2 of 25 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications 3.3 V Operation 3.3 V VOCM to VO, cm Performance 3.3 V General Performance 5 V Operation 5 V VOCM to VO, cm Performance 5 V General Performance Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Operational Description Definition of Terms Differential Voltage Common-Mode Voltage Balance Theory of Operation Analyzing an Application Circuit Setting the Closed-Loop Gain Estimating the Output Noise Voltage Impact of Mismatches in the Feedback Networks Input Common-Mode Voltage Range Minimum RG Value Setting the Output Common-Mode Voltage Calculating the Input Impedance for an Application Circuit Terminating a Single-Ended Input Terminating a Single-Ended Input in a Single-Supply Applications Input Common-Mode Adjustment with DC Biased Source Input Common-Mode Adjustment with Resistors Layout, Grounding, and Bypassing High Performance ADC Driving Outline Dimensions Ordering Guide
