TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit V type S = 3.3 V, TA unless otherwise specified Min Max Input characteristics – continued. Input capacitance CIN Common mode +25°C 01 1 typical pF Common mode CMRR ∆VICM = 0.5 V dc; +25°C 01 -77 dB rejection mode RF = RG = 10 kΩ, RL = open circuit -55°C to +105°C -76 typical Output characteristics. Output voltage VOUT Each single ended output, +25°C 01 0.11 1.74 V RF = RG = 10 kΩ -55°C to +105°C 1.54 Linear output current Each single ended output, +25°C 01 30 typical mA f = 1 MHz, THD ≤ 60 dBc Output balance error f = 1 MHz +25°C 01 55 typical dB 3.3 V VOCM to VO,CM performance. VOCM dynamic performance. -3 dB bandwidth VO,CM = 0.1 VP-P +25°C 01 745 typical MHz Slew rate SR VO,CM = 2 VP-P , 25% to 75% +25°C 01 828 typical V/µs VOCM input characteristics. Input voltage range VIN +25°C 01 0.8 1.1 V Input resistance RIN +25°C 01 7.0 10.3 kΩ Input offset voltage V +25°C 01 -25 +31 mV IO VOS,CM = VO,CM – VOCM; VIP = VIN = VOCM = 0 V See footnotes at end of table. DLA LAND AND MARITIME SIZE CODE IDENT NO. DWG NO. COLUMBUS, OHIOA16236V62/13615 REV PAGE 6 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/13615 REV
