Datasheet ADA4930-1 (Analog Devices) - 10
DescriptionUltralow Noise Drivers for Low Voltage ADCs
Pages / Page17 / 10 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/13615
File Format / SizePDF / 220 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/13615
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit V type S = 5 V, TA unless otherwise specified Min Max Noise / harmonic performance - continued. Input voltage noise f = 100 kHz +25°C 01 1.2 typical nV / -55°C to +105°C 1.3 typical Hz Input current noise f = 100 kHz +25°C 01 2.8 typical pA / Hz DC performance. Input offset voltage V -55°C to +105°C 01 -3.1 +3.1 mV IO VIP = VIN = VOCM = 0 V, RL = open circuit Input offset voltage drift ∆VIO -55°C to +105°C 01 1.8 typical µV / °C Input bias current IIB +25°C 01 -34 -15 µA Input bias current drift ∆IIB -55°C to +105°C 01 -0.05 typical µA / °C Input offset current IIO +25°C 01 -0.82 +0.82 µA Open loop gain RF = RG = 10 kΩ, ∆VO = 1 V, +25°C 01 64 typical dB RL = open circuit -55°C to +105°C 61 typical Input characteristics. Input common mode +25°C 01 0.3 2.8 V voltage range Input resistance RIN Differential +25°C 01 150 typical kΩ Common mode 3 typical MΩ See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/13615
REV PAGE 10 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/13615 REV
