Datasheet ADL5561 (Analog Devices) - 10 Manufacturer Analog Devices Description 2.9 GHz Ultralow Distortion RF/IF Differential Amplifier Pages / Page 25 / 10 — Data Sheet. ADL5561. –40. AV MAXIMUM. AV MID. AV MINIMUM. –60. –20. –80. … Revision G File Format / Size PDF / 773 Kb Document Language English
Data Sheet. ADL5561. –40. AV MAXIMUM. AV MID. AV MINIMUM. –60. –20. –80. c) B. –100. 3 (. = 1. = 20. OIP. 3, R. D –120. D IM. –140. –160. –120. 100. 150. 200. 250
Model Line for this Datasheet Text Version of Document Data Sheet ADL5561 60 –40 0 AV MAXIMUM AV MAXIMUM AV MID AV MID AV MINIMUM AV MINIMUM 50 –60 –20 c) 40 B –80 –40 c) B ) (d m (d Ω B 0 Ω d k 30 –100 –60 3 ( = 1 = 20 L L OIP R 3, R 3, 20 D –120 –80 D IM IM 10 –140 –100 0 –160 –120 0 50 100 150 200 250 18 00 50 100 150 200 250 20 0 4- 4-FREQUENCY (MHz) 00FREQUENCY (MHz) 00 08 08 Figure 9. Output Third-Order Intercept at Three Gains, Output Level at 2 V p-p Figure 12. Two-Tone Output IMD vs. Frequency, Composite, RL = 200 Ω Output Level at 2 V p-p Composite, RL = 200 Ω and RL = 1 kΩ60 50 +85°C MAX GAIN +25°C MAX GAIN –40°C MAX GAIN 45 50 40 35 40 ) ) 30 m m B B d 30 d 25 3 ( 3 ( OIP OIP 20 20 15 10 10 5 0 0 0 50 100 150 200 250 1 19–2 –1 0 1 2 3 4 5 0 02 4- 4-FREQUENCY (MHz) 00P 00 08OUT/TONE (dBm) 08 Figure 10. Output Third-Order Intercept vs. Frequency, Over Temperature, Figure 13. Output Third-Order Intercept (OIP3) vs. Power (POUT), Output Level at 2 V p-p Composite, RL = 200 Ω Frequency 140 MHz, AV = 15.5 dB60 –70 AV MAXIMUM AV MAXIMUM AV MID AV MID A –75 A 55 V MINIMUM V MINIMUM –80 50 ) –85 m B d Bc) 45 d –90 3 ( D ( OIP IM –95 40 –100 35 –105 30 –110 0 50 100 150 200 250 05 00 50 100 150 200 250 06 0 4- 4-FREQUENCY (MHz) 00FREQUENCY (MHz) 00 08 08 Figure 11. OIP3 vs. Frequency (Single-Ended Input) Figure 14. IMD vs. Frequency (Single-Ended Input) Rev. G | Page 9 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
