21 /10 — Data Sheet. AD8429. 160. 3.0. G = 1k. 140. G = 100. IOS 2.5. G = 10. 120. …
Revision
A
PDF / 735 Kb
Data Sheet. AD8429. 160. 3.0. G = 1k. 140. G = 100. IOS 2.5. G = 10. 120. A) n. G = 1. 2.0. 100. BANDWIDTH. LIMITED. 1.5. CURR. RR (. CURRE. T E S. 1.0. T U. INP. –10
Data SheetAD8429160403.0IG = 1kB+I140B–G = 10030IOS 2.5G = 10A)120A) n(n(G = 1202.0NT100NTEB)BANDWIDTHdLIMITED80101.5CURRRR (CURRET E SCMASF60BIF01.0OUTT U40INPINP–100.5200–200 9 1101001k10k100k1M 10 1 –45 –30 –150153045607590105 120 135 01 0- 0- FREQUENCY (Hz) 73 TEMPERATURE (°C) 73 09 09 Figure 10. CMRR vs. Frequency Figure 13. Input Bias Current and Input Offset Current vs. Temperature 14040G = 100GAIN = 1G = 1k30120 G = 102010010G = 1))0B/V80dVBANDWIDTHµR (LIMITED–10RRR (60CM–20CM40–30–4020–50 NORMALIZED AT 25°C0–60 4 1101001k10k100k1M 1 1 –40 –25 –105203550658095110 125 1 1 1 0- 0- 73 FREQUENCY (Hz) 73 TEMPERATURE (°C) 09 09 Figure 11. CMRR vs. Frequency, 1 kΩ Source Imbalance Figure 14. CMRR vs. Temperature (G = 1), Normalized at 25°C 1210.0V) µ9.5E (10G9.0A T LA)8.58VO(m NT8.0SETEF F67.5O TCURR Y7.0PULN4PI NUP6.5SE I G N6.02A H C5.505.00100200300400500600700 2 2 1 1 –50–30–101030507090110130 02 0- 0- WARM-UP TIME (s) 73 TEMPERATURE (°C) 73 09 09 Figure 12. Change in Input Offset Voltage (VOSI) vs. Warm-Up Time Figure 15. Supply Current vs. Temperature (G = 1) Rev. A | Page 9 of 20 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE RG Power Dissipation REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Common-Mode Rejection Ratio over Frequency Power Supplies and Grounding Reference Pin INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION Input Voltages Beyond the Rails Large Differential Input Voltage at High Gain IMAX RADIO FREQUENCY INTERFERENCE (RFI) CALCULATING THE NOISE OF THE INPUT STAGE Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation OUTLINE DIMENSIONS ORDERING GUIDE
