Datasheet AD8229-KGD (Analog Devices) - 4
Description1 nV/√Hz Low Noise 210°C Instrumentation Amplifier
Pages / Page8 / 4 — AD8229-KGD. Known Good Die. Parameter. Test Conditions/Comments. Min. …
File Format / SizePDF / 148 Kb
AD8229-KGD. Known Good Die. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8229-KGD Known Good Die Parameter Test Conditions/Comments Min Typ Max Unit
link to page 5 link to page 5 link to page 5
DYNAMIC RESPONSE Small Signal Bandwidth – 3 dB G = 1 15 MHz G = 10 4 MHz G = 100 1.2 MHz G = 1000 0.15 MHz Settling Time 0.01% 10 V step G = 1 0.75 µs G = 10 0.65 µs G = 100 0.85 µs G = 1000 5 µs Settling Time 0.001% 10 V step G = 1 0.9 µs G = 10 0.9 µs G = 100 1.2 µs G = 1000 7 µs Slew Rate G = 1 to 100 22 V/µs GAIN2 G = 1 + (6 kΩ/R ) G Gain Range 1 1000 V/V Gain Error V = ±10 V OUT G = 1 0.01 0.03 % G = 10 0.05 0.3 % G = 100 0.05 0.3 % G = 1000 0.1 0.3 % Gain Nonlinearity V = −10 V to +10 V OUT G = 1 to 1000 R = 10 kΩ 2 ppm L Gain vs. Temperature G = 1 −40°C to +210°C 2 5 ppm/°C G > 10 −40°C to +210°C −100 ppm/°C INPUT Impedance (Pin to Ground)3 1.5||3 GΩ||pF Input Operating Voltage Range4 V = ±5 V to ±18 V −V + 2.8 +V − 2.5 V S S S for dual supplies Over Temperature −40°C to +210°C −V + 2.8 +V − 2.5 V S S OUTPUT Output Swing R = 2 kΩ −V + 1.9 +Vs − 1.5 V L S High Temperature T = 210°C −V + 1.1 +Vs − 1.1 V A S Output Swing R = 10 kΩ −V + 1.8 +Vs − 1.2 V L S High Temperature T = 210°C −V + 1.1 +Vs − 1.1 V A S Short-Circuit Current 35 mA REFERENCE INPUT R 10 kΩ IN I V +, V − = 0 V 70 µA IN IN IN Voltage Range −V +V V S S Reference Gain to Output 1 V/V Reference Gain Error 0.01 % Rev. 0 | Page 4 of 8 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pad Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
