AD8290TYPICAL PERFORMANCE CHARACTERISTICS3525302025))15%20%((SSITTUN15UNI10105500 03 0 8928948968989009029049069080.29880.29940.30000.30060.3012 6 5- 00 74 0.29910.29970.30030.3009OUTPUT VOLTAGE (mV) 5- 06 74 EXCITATION CURRENT (mA) 06 Figure 3. Output Offset Voltage at 2.6 V Supply Figure 6. Excitation Output Current for 3 kΩ RSET at 2.6 V Supply 3525302025))15%20%((SSTTUNI15UNI1010550 4 0892894896898900902904906908 -00 0.29880.29940.30000.30060.3012 07 0 745 0.29910.29970.30030.3009OUTPUT VOLTAGE (mV) 5- 06 74 EXCITATION CURRENT (mA) 06 Figure 4. Output Offset Voltage at 3.6 V Supply Figure 7. Excitation Output Current for 3 kΩ RSET at 3.6 V Supply 3525302025))15%20%((SSTITUNI15UN1010550 5 0 00 8928948968989009029049069080.29880.29940.30000.30060.3012 5- 08 0 74 0.29910.29970.30030.3009OUTPUT VOLTAGE (mV) 5- 06 74 EXCITATION CURRENT (mA) 06 Figure 5. Output Offset Voltage at 5.0 V Supply Figure 8. Excitation Output Current for 3 kΩ RSET at 5.0 V Supply Rev. B | Page 7 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER HIGH POWER SUPPLY REJECTION (PSR) AND COMMON-MODE REJECTION (CMR) 1/f NOISE CORRECTION CURRENT SOURCE APPLICATIONS INFORMATION TYPICAL CONNECTIONS CURRENT EXCITATION ENABLE/DISABLE FUNCTION OUTPUT FILTERING CLOCK FEEDTHROUGH MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT POWER SUPPLY BYPASSING DUAL-SUPPLY OPERATION PRESSURE SENSOR BRIDGE APPLICATION TEMPERATURE SENSOR APPLICATION ADC/MICROCONTROLLER OUTLINE DIMENSIONS ORDERING GUIDE
