AD8290405035403025))30(%%S(20TS TUNIUNI20151010500 31 26 0.00300.00400.00500.00600.0070 0 –35–15525456585105125 0 0.00350.00450.00550.0065 5- 5- 74 74 NONLINEARITY (%)DRIFT (µV/°C) 06 06 Figure 15. Percent Nonlinearity at 2.6 V Supply Figure 18. Output Offset Voltage Drift from −40°C to +85°C at 2.6 V Supply 3550304025))3020%%((SSTIT15UNIUN2010105000.00300.00400.00500.00600.0070 32 27 0 –35–155254565851051250.00350.00450.00550.0065 0 5- 5- 74 NONLINEARITY (%) 74 DRIFT (µV/°C) 06 06 Figure 16. Percent Nonlinearity at 3.6 V Supply Figure 19. Output Offset Voltage Drift from −40°C to +85°C at 3.6 V Supply 455040403530))30%25%((SSITT20UNUNI20151010500 33 0.00300.00600.00900.01200.0150 8 0 –35–15525456585105125 02 5- 0.00450.00750.01050.0135 5- 74 74 DRIFT (µV/°C)NONLINEARITY (%) 06 06 Figure 17. Percent Nonlinearity at 5.0 V Supply Figure 20. Output Offset Voltage Drift from −40°C to +85°C at 5.0 V Supply Rev. B | Page 9 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER HIGH POWER SUPPLY REJECTION (PSR) AND COMMON-MODE REJECTION (CMR) 1/f NOISE CORRECTION CURRENT SOURCE APPLICATIONS INFORMATION TYPICAL CONNECTIONS CURRENT EXCITATION ENABLE/DISABLE FUNCTION OUTPUT FILTERING CLOCK FEEDTHROUGH MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT POWER SUPPLY BYPASSING DUAL-SUPPLY OPERATION PRESSURE SENSOR BRIDGE APPLICATION TEMPERATURE SENSOR APPLICATION ADC/MICROCONTROLLER OUTLINE DIMENSIONS ORDERING GUIDE
