Datasheet AD8231 (Analog Devices) - 7
DescriptionZero Drift, Digitally Programmable Instrumentation Amplifier
Pages / Page17 / 7 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12646
File Format / SizePDF / 218 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12646
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit V type S = 5 V, VREF = 2.5 V, TA G = 1, R L = 10 kΩ, Min Max unless otherwise specified Instrumentation amplifier – continued. Dynamic performance. Bandwidth BW G = 1 +25°C 01 2.7 typical MHz G = 2 2.5 typical Gain bandwidth GBW G = 4 to 128 +25°C 01 7 typical MHz Slew rate SR +25°C 01 1.1 typical V/µs Output characteristics. Output voltage high VOH RL = 100 kΩ to ground +25°C 01 4.9 V RL = 10 kΩ to ground 4.8 Output voltage low VOL RL = 100 kΩ to 5 V +25°C 01 100 mV RL = 10 kΩ to 5 V 200 Short circuit current ISC +25°C 01 70 typical mA Digital interface. Input voltage low VIL -55°C to +125°C 01 1.0 V Input voltage high VIH -55°C to +125°C 01 4.0 V Setup time to CS high -55°C to +125°C 01 50 ns Hold time after CS -55°C to +125°C 01 20 ns high Operational amplifier. Input characteristics. Offset voltage VOS +25°C 01 15 µV Offset voltage ∆VOS/ -55°C to +125°C 01 0.06 µV/°C temperature drift ∆T Input bias current IIB +25°C 01 500 pA -55°C to +125°C 5 nA See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12646
REV PAGE 7 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/12646 REV
