Datasheet AD8221 (Analog Devices) - 9
DescriptionPrecision Instrumentation Amplifier
Pages / Page13 / 9 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16619
File Format / SizePDF / 80 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16619
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit T type A Min Max Output RL = 10 k Output swing V V S = 2.3 V to 5 V 25C 01 -VS +VS + 1.1 – 1.2 -55C to +125C -V S +VS + 1.4 – 1.3 Output swing V V S = 5 V to 18 V 25C 01 -VS +VS + 1.2 – 1.4 -55C to +125C -V S +VS + 1.6 – 1.5 Short circuit current IOS 25C 01 18 typical mA Temperature range 01 -55 +125 C specified performance 1/ Testing and other quality control techniques are used to the extent deemed necessary to assure product performance over the specified temperature range. Product may not necessarily be tested across the full temperature range and all parameters may not necessarily be tested. In the absence of specific parametric testing, product performance is assured by characterization and/or design. 2/ Unless otherwise specified, VS = 15 V, VREF = 0 V, G = 1, and RL = 2 k. 3/ Does not include the effects of external resistor RG. 4/ Total RTI VOS = (VOSI) + (VOSO/G). 5/ The || symbolizes that the input impedance is being represented as the resistance value is in parallel with the capacitance. 6/ One input grounded. G = 1.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16619
REV PAGE 9
