Datasheet AMP02 (Analog Devices) - 7 Manufacturer Analog Devices Description High Accuracy 8-Pin Instrumentation Amplifier Pages / Page 13 / 7 — AMP02. 140. A = 25. G = 1000. S =. 15V. 120. 130. G = 100. 100. G = 10. … Revision E File Format / Size PDF / 234 Kb Document Language English
AMP02. 140. A = 25. G = 1000. S =. 15V. 120. 130. G = 100. 100. G = 10. 110. GE GAIN –. G = 1. LTA. –20. COMMON-MODE REJECTION – dB. VCM = 2V p-p. –40. 10k
Text Version of Document AMP02 80 140 140 T T A = 25 ⴗC A = 25 ⴗC V G = 1000 V S = ⴞ15V G = 1000 S = ⴞ15V 120 130 60 G = 100 B 100 120 d G = 100 40 G = 10 80 110 G = 10 20 GE GAIN – 60 100 G = 1 LTA G = 1 0 VO 40 90 T –20 A = 25 ⴗC COMMON-MODE REJECTION – dB 20 V 80 S = ⴞ15V COMMON-MODE REJECTION – dB VCM = 2V p-p –40 0 70 1k 10k 100k 1M 10M 1 10 100 1k 10k 100k 1 10 100 1k FREQUENCY – Hz FREQUENCY – Hz VOLTAGE GAIN – G TPC 10. Closed-Loop Voltage TPC 11. Common-Mode Rejection TPC 12. Common-Mode Rejection Gain vs. Frequency vs. Frequency vs. Voltage Gain140 140 1.000 G = 1000 TA = 25 ⴗC G = 100 G = 1000 VS = ⴞ15V 120 120 R G = 10 G = 10 G = 100 L = 600 ⍀V ION – % OUT = 20V p-p 100 100 T R G = 1 G = 1 O 0.100 80 80 Y REJECTION – dB Y REJECTION – dB 60 60 G = 100 0.010 40 40 L HARMONIC DIST WER SUPPL T WER SUPPL G = 1 A = 25 ⴗC TA = 25 ⴗC TA PO 20 20 V PO S = ⴞ15V VS = ⴞ15V TO G = 10 ⌬VS = ⴞ1V ⌬VS = ⴞ1V 0 0 0.01 1 10 100 1k 10k 100k 1 10 100 1k 10k 100k 10 100 1k 10k FREQUENCY – Hz FREQUENCY – Hz FREQUENCY – Hz TPC 13. Positive PSR vs. Frequency TPC 14. Negative PSR vs. Frequency TPC 15. Total Harmonic Distortion vs. Frequency70 1k T T A = 25 ⴗC A = 25 ⴗC V Hz VS = ⴞ15V S = ⴞ15V 100mV 1s 60 G = 1000 f = 1kHz Hz 50 100 200nV/DIV 40 – GE 30 NOISE – nV/ A E T L G O NOISE DENSITY – nV/ 10 E 20 LTA G VO LTA NOISE V 10 VO 0 1 1 10 100 1k 10k 100k 1 10 100 1k TIME – S FREQUENCY – Hz VOLTAGE GAIN – G TPC 16. Voltage Noise Density TPC 17. RTI Voltage Noise TPC 18. 0.1 Hz to 10 Hz Noise vs. Frequency Density vs. Gain AV = 1000 –6– REV. E Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE WAFER TEST LIMITS Typical Performance Characteristics APPLICATIONS INFORMATION Input and Output Offset Voltages Input Bias and Offset Currents Gain Common-Mode Rejection Grounding Sense and Reference Terminals Overvoltage Protection Power Supply Considerations OUTLINE DIMENSIONS Revision History
