Datasheet AMP02 (Analog Devices) - 8
DescriptionHigh Accuracy 8-Pin Instrumentation Amplifier
Pages / Page13 / 8 — AMP02. 120. A = 25. TA = 25. S =. 15V. VS =. 100. L = 1k. OUT = 20mA p-p. …
RevisionE
File Format / SizePDF / 234 Kb
AMP02. 120. A = 25. TA = 25. S =. 15V. VS =. 100. L = 1k. OUT = 20mA p-p. – V. A T. ANCE –. -PEAK AMPLITUDE –. OUTPUT V. OUTPUT IMPED. PEAK-. –20. 10k. 100k
AMP02 120 A = 25 TA = 25 S = 15V VS = 100 L = 1k OUT = 20mA p-p – V A T ANCE – -PEAK AMPLITUDE – OUTPUT V OUTPUT IMPED PEAK- –20 10k 100k
AMP02 30 16 120 T T A = 25
C TA = 25
C A = 25
C V V S =
15V VS =
15V S =
15V V 14 100 25 R I L = 1k
OUT = 20mA p-p 12
– V 80 20 GE 10 A T ANCE – 60 L 15 O 8 40 -PEAK AMPLITUDE – 6 O 10 T OUTPUT V 20 4 OUTPUT IMPED PEAK- 5 2 0 0 0 –20 100 1k 10k 100k 1M 10 100 1k 10k 100k 100 1k 10k 100k 1M 10M FREQUENCY – Hz LOAD RESISTANCE –
FREQUENCY – Hz
TPC 19. Maximum Output Swing TPC 20. Maximum Output Voltage TPC 21. Closed Loop Output vs. Frequency vs. Load Resistance Impedance vs. Frequency
8 8 VS =
15V 7 7 TA = –40
C, +25
C, +85
C s 6 6
V T 5 A = –25
C, +25
C, +85
C TE – 5 4 Y CURRENT – mA 4 SLEW RA 3 SUPPL 3 2 1 1 0
5
10
15
20 1 10 100 1k SUPPLY VOLTAGE – V VOLTAGE GAIN – G
TPC 22. Supply Current TPC 23. Slew Rate vs. vs. Supply Voltage Voltage Gain REV. E –7– Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE WAFER TEST LIMITS Typical Performance Characteristics APPLICATIONS INFORMATION Input and Output Offset Voltages Input Bias and Offset Currents Gain Common-Mode Rejection Grounding Sense and Reference Terminals Overvoltage Protection Power Supply Considerations OUTLINE DIMENSIONS Revision History
