Datasheet AD625 (Analog Devices) - 4
DescriptionProgrammable Gain Instrumentation Amplifier
Pages / Page16 / 4 — AD625. AD625A/J/S. AD625B/K. AD625C. Model. Min. Typ. Max. Unit. boldface
RevisionD
File Format / SizePDF / 503 Kb
AD625 AD625A/J/S AD625B/K AD625C Model Min Typ Max Unit boldface
AD625 AD625A/J/S AD625B/K AD625C Model Min Typ Max Min Typ Max Min Typ Max Unit
NOISE Voltage Noise, 1 kHz R.T.I. 4 4 4 nV/√Hz R.T.O. 75 75 75 nV/√Hz R.T.I., 0.1 Hz to 10 Hz G = 1 10 10 10 µV p-p G = 10 1.0 1.0 1.0 µV p-p G = 100 0.3 0.3 0.3 µV p-p G = 1000 0.2 0.2 0.2 µV p-p Current Noise 0.1 Hz to 10 Hz 60 60 60 pA p-p SENSE INPUT RIN 10 10 10 kΩ IIN 30 30 30 µA Voltage Range ±10 ±10 ±10 V Gain to Output 1 ± 0.01 1 ± 0.01 1 ± 0.01 % REFERENCE INPUT RIN 20 20 20 kΩ IIN 30 30 30 µA Voltage Range ±10 ±10 ±10 V Gain to Output 1 ± 0.01 1 ± 0.01 1 ± 0.01 % TEMPERATURE RANGE Specified Performance J/K Grades 0 +70 0 +70 °C A/B/C Grades –40 +85 –40 +85 –40 +85 °C S Grade –55 +125 °C Storage –65 +150 –65 +150 –65 +150 °C POWER SUPPLY Power Supply Range ±6 to ±18 ±6 to ±18 ±6 to ± 18 V Quiescent Current 3.5 5 3.5 5 3.5 5 mA NOTES 1Gain Error and Gain TC are for the AD625 only. Resistor Network errors will add to the specified errors. 2VDL is the maximum differential input voltage at G = 1 for specified nonlinearity. VDL at other gains = 10 V/G. VD = actual differential input voltage. Example: G = 10, VD = 0.50; VCM = 12 V – (10/2 × 0.50 V) = 9.5 V. Specifications subject to change without notice. All min and max specifications are guaranteed. Specifications shown in
boldface
are tested on all production units at final electrical test. Results from those tests are used to calculate outgoing quality levels. REV. D –3–
