Datasheet AD625 (Analog Devices) - 5
DescriptionProgrammable Gain Instrumentation Amplifier
Pages / Page11 / 5 — STANDARD. 5962-87719. MICROCIRCUIT DRAWING
File Format / SizePDF / 71 Kb
STANDARD 5962-87719 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics – Continued. Conditions 1/ Test Symbol -55C  TA +125C Group A Device Limits Unit unless otherwise specified subgroups type Min Max Power supply rejection PSRR G = 10 2/ 1 01 85 dB Power supply rejection PSRR G = 100 2/ 1 01 95 dB Power supply rejection PSRR G = 1000 1 01 100 dB 1/ VS = 15 V, RL = 2 k, unless otherwise specified. 2/ Guaranteed if not tested to the limits specified. 3/ Gain error is a function of external resistors. 3.5 Marking. Marking shall be in accordance with MIL-PRF-38535, appendix A. The part shall be marked with the PIN listed in 1.2 herein. In addition, the manufacturer's PIN may also be marked. For packages where marking of the entire SMD PIN number is not feasible due to space limitations, the manufacturer has the option of not marking the "5962-" on the device. 3.5.1 Certification/compliance mark. A compliance indicator “C” shall be marked on all non-JAN devices built in compliance to MIL-PRF-38535, appendix A. The compliance indicator “C” shall be replaced with a "Q" or "QML" certification mark in accordance with MIL-PRF-38535 to identify when the QML flow option is used. 3.6 Certificate of compliance. A certificate of compliance shall be required from a manufacturer in order to be listed as an approved source of supply in MIL-HDBK-103 (see 6.6 herein). The certificate of compliance submitted to DLA Land and Maritime -VA prior to listing as an approved source of supply shall affirm that the manufacturer's product meets the requirements of MIL-PRF-38535, appendix A and the requirements herein. 3.7 Certificate of conformance. A certificate of conformance as required in MIL-PRF-38535, appendix A shall be provided with each lot of microcircuits delivered to this drawing. 3.8 Notification of change. Notification of change to DLA Land and Maritime -VA shall be required for any change that affects this drawing. 3.9 Verification and review. DLA Land and Maritime, DLA Land and Maritime's agent, and the acquiring activity retain the option to review the manufacturer's facility and applicable required documentation. Offshore documentation shall be made available onshore at the option of the reviewer.
STANDARD
SIZE
A 5962-87719 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990
F 5
DSCC FORM 2234 APR 97
