Datasheet ADL5904 (Analog Devices) - 5
DescriptionDC to 6 GHz, 45 dB TruPwr Detector with Envelope Threshold Detection
Pages / Page27 / 5 — Data Sheet. ADL5904. Parameter. Test Conditions/Comments. Min Typ. Max. …
RevisionB
Data Sheet. ADL5904. Parameter. Test Conditions/Comments. Min Typ. Max. Unit
Data Sheet ADL5904 Parameter Test Conditions/Comments Min Typ Max Unit
Threshold Variation vs. −40°C < TA < +85°C, PIN ≈ 10 dBm ±0.1 dB Temperature −40°C < TA < +85°C, PIN ≈ 0 dBm −0.2/+0.1 dB −40°C < TA < +85°C, PIN ≈ −10 dBm 0.1/0.3 dB −40°C < TA < +105°C, PIN ≈ 10 dBm ±0.1 dB −40°C < TA < +105°C, PIN ≈ 0 dBm −0.2/+0.1 dB −40°C < TA < +105°C, PIN ≈ −10 dBm 0.1/0.3 dB f = 1900 MHz ±1.0 dB Input Range 45 dB Input Level, ±1.0 dB Maximum Three-point calibration at −20 dBm, 0 dBm, and +10 dBm 17 dBm Minimum −28 dBm VRMS Output Voltage RFIN pin = 10 dBm 1.62 V RFIN pin = −20 dBm 0.55 V VRMS Deviation vs. Temperature Deviation from output at 25°C −40°C < TA < +85°C, PIN = 10 dBm −0.1/+0.3 dB −40°C < TA < +105°C, PIN = 10 dBm −0.1/+0.3 dB −40°C < TA < +85°C, PIN = −15 dBm −0.2/−0.1 dB −40°C < TA < +105°C, PIN = −15 dBm −0.4/−0.2 dB VRMS Logarithmic Slope PIN = −20 dBm to 0 dBm 34.8 mV/dB PIN = 0 dBm to 10 dBm 36.9 mV/dB VRMS Logarithmic Intercept PIN = −20 dBm to 0 dBm −35.9 dBm PIN = 0 dBm to 10 dBm −33.8 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 774 mV For threshold detection at 0 dBm 241 mV For threshold detection at −10 dBm 78 mV Threshold Variation vs. −40°C < TA < +85°C, PIN ≈ 10 dBm −0.2/+0.1 dB Temperature −40°C < TA < +85°C, PIN ≈ 0 dBm −0.1/0 dB −40°C < TA < +85°C, PIN ≈ −10 dBm ±0.2 dB −40°C < TA < +105°C, PIN ≈ 10 dBm −0.2/+0.1 dB −40°C < TA < +105°C, PIN ≈ 0 dBm −0.1/0 dB −40°C < TA < +105°C, PIN ≈ −10 dBm ±0.2 dB f = 2600 MHz ±1.0 dB Input Range 43.5 dB Input Level, ±1.0 dB Maximum Three-point calibration at −20 dBm, 0 dBm, and +10 dBm 16 dBm Minimum −27.5 dBm VRMS Output Voltage RFIN pin = 10 dBm 1.6 V RFIN pin = −20 dBm 0.51 V VRMS Deviation vs. Temperature Deviation from output at 25°C −40°C < TA < +85°C, PIN = 10 dBm −0.3/+0.3 dB −40°C < TA < +105°C, PIN = 10 dBm −0.3/+0.3 dB −40°C < TA < +85°C, PIN = −15 dBm −0.2/0 dB −40°C < TA < +105°C, PIN = −15 dBm −0.3/0 dB VRMS Logarithmic Slope PIN = −20 dBm to 0 dBm 36.1 mV/dB PIN = 0 dBm to 10 dBm 37.5 mV/dB VRMS Logarithmic Intercept PIN = −20 dBm to 0 dBm −34 dBm PIN = 0 dBm to 10 dBm −32.7 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 775 mV For threshold detection at 0 dBm 236 mV For threshold detection at −10 dBm 76 mV Rev. B | Page 5 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION BASIC CONNECTIONS FOR RMS MEASUREMENT CHOOSING A VALUE FOR CRMS VRMS CALIBRATION AND ERROR CALCULATION BASIC CONNECTIONS FOR THRESHOLD DETECTION Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION EVALUATION BOARD SCHEMATIC AND CONFIGURATION OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
