Datasheet ADL5506 (Analog Devices) - 9
Description30 MHz to 4.5 GHz, 45 dB RF Detector
Pages / Page25 / 9 — Data Sheet. ADL5506. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. …
RevisionA
Data Sheet. ADL5506. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
Data Sheet ADL5506 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Data Sheet ADL5506 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Supply Voltage, VPOS 5.5 V or any other conditions above those indicated in the operational RF Input Power, RFIN1, 2 15 dBm section of this specification is not implied. Operation beyond Equivalent Voltage, Sine Wave Input 1.25 V rms the maximum operating conditions for extended periods may Internal Power Dissipation 75 mW affect product reliability. θJA (WLCSP) 260°C/W Maximum Junction Temperature 145°C
ESD CAUTION
Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C 1 Driven from a 50 Ω source. 2 Under 50 Ω input matched condition. Rev. A | Page 7 of 23 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT LOG CONFORMANCE ERROR CALCULATION Filter Capacitor Input Coupling Options Effect of Waveform Type on Intercept Temperature Drift at High Frequencies Operation Above 4.5 GHz VLOG Output Noise VLOG Pulse Response Time Device Handling EVALUATION BOARD LAND PATTERN AND SOLDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
