Datasheet HMC913LC4B (Analog Devices) - 9
DescriptionSUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA), 0.6 - 20 GHz
Pages / Page10 / 9 — HMC913LC4B. SUCCESSIVE DETECTION LOG VIDEO. AMPLIFIER (SDLVA), 0.6 - 20 …
File Format / SizePDF / 655 Kb
HMC913LC4B. SUCCESSIVE DETECTION LOG VIDEO. AMPLIFIER (SDLVA), 0.6 - 20 GHz. Evaluation PCB
HMC913LC4B SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA), 0.6 - 20 GHz Evaluation PCB
HMC913LC4B
v05.0614
T M S - As LV SD
List of Materials for Evaluation PCB 120257 [1]
Item Description The circuit board used in the application should J1 K-Type Connector use RF circuit design techniques. Signal lines sho- J2 SMA Connector uld have 50 ohm impedance while the package J3 - J5 DC Pins ground leads and exposed paddle should be con- C1, C2 33 pF Capacitor, 0201 Pkg. nected directly to the ground plane similar to that C3, C4 10k pF Capacitor, 0402 Pkg. shown. A sufficient number of via holes should be C5 47 pF Capacitor, 0402 Pkg. used to connect the top and bottom ground planes. C6, C7 4.7 µF Capacitor, CASE A Pkg. The evaluation circuit board shown is available from R2, R3, R5 0 Ohm Resistor, 0402 Pkg. Hittite upon request. R7 0 Ohm Resistor, 0201 Pkg. R8 49.9 Ohm Resistor, 0201 Pkg. U1 HMC913LC4B SDLVA PCB [2] 120255 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 or Arlon 25 FR Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
9
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
