HMC909LP4E v02.0511 RMS POWER DETECTORSINGLE-ENDED, DC - 5.8 GHzElectrical Specifications II TA = +25 °C, Vcc = 5V, Sci4 = Sci1 = 0V, Sci3 = Sci2 = 5V, Unless Otherwise Noted Parameter typ. typ. typ. typ. typ. typ. typ. typ. Units Input Frequency 100 900 1900 2200 2700 3500 3900 5800 MHz Modulation Deviation (Output deviation from reference, which is measured with CW input at equivalent input signal power) WCDMA 4 Carrier (TM1-64 DPCH) at +25 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.4 dB WCDMA 4 Carrier (TM1-64 DPCH) at +85 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.4 dB WCDMA 4 Carrier (TM1-64 DPCH) at -40 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.3 dB Logarithmic Slope and Intercept [1] Logarithmic slope 36.2 36.3 36.9 37.5 39.2 42.6 44.6 66.9 mV/dB Logarithmic Intercept -70.1 -69.7 -68.5 -67.7 -65.6 -61.8 -59.1 -44.5 dBm Max. Input Power at ±1dB error -12 -12 -11 -11 -12 -12 -11 -12 dBm Min. Input Power at ±1dB error -52 -52 -51 50 -50 -49 -47 -36 dBm 11 [1] With WCDMA 4 Carrier (TM1-64 DPCH) t RMSOUT vs. Pin with DifferentRMSOUT Error vs. Pin with Different M Modulations @ 1900 MHz [1]Modulations @ 1900 MHz [1] s 3 4 - 3 CW 2.5 Ideal WCDMA 4 carriers CW 2 WCDMA single carrier rs WCDMA 4 carriers 2 WCDMA single carrier o 1 (V) (dB) t 1.5 0 c -1 RMSOUT ERROR e 1 -2 t 0.5 e -3 0 -4 D -70 -60 -50 -40 -30 -20 -10 0 -60 -50 -40 -30 -20 -10 r INPUT POWER (dBm) INPUT POWER (dBm) e w o P [1] Data was taken at sci4=sci1=0V, sci3=sci2=5V, shortest integration time is for scI=0000, allowed longest integration time is for scI=1100 Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com 11 - 2 Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
