Datasheet HMC909LP4E (Analog Devices) - 9
DescriptionRMS Power Detector Single-Ended SMT, DC - 5.8 GHz
Pages / Page22 / 9 — HMC909LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 5.8 GHz. Typical …
File Format / SizePDF / 3.3 Mb
HMC909LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 5.8 GHz. Typical Supply Current vs. Pin, Vcc = 5V
HMC909LP4E RMS POWER DETECTOR SINGLE-ENDED, DC - 5.8 GHz Typical Supply Current vs Pin, Vcc = 5V
HMC909LP4E
v02.0511
RMS POWER DETECTOR SINGLE-ENDED, DC - 5.8 GHz Typical Supply Current vs. Pin, Vcc = 5V Input Return Loss vs. Frequency
50 0 -5 45 (mA) (dB) -10 40 LOSS -15 CURRENT +25C +85C -40C -20 35 RETURN SUPPLY -25 30 -30 -70 -60 -50 -40 -30 -20 -10 0 0 1 2 3 4 5 6 11 INPUT POWER (dBm) FREQUENCY (GHz) t
Output Ripple & Rise/Fall Time vs. Integration
M
Setting [Sci4,Sci3,Sci2,Sci1] in Decimal
s 2100 100000 - Ripple with WCDMA4TM 1800 Ripple with WCDMA1TM 10000 Ripple with 8 Tone (1kHz seperation) Ripple with 8 Tone (10kHz seperation) RI rs 1500 1000 SE/ o FALL TI 1200 100 t 900 10 c ME (us) e 600 1 Rise Time t Fall Time OUTPUT RIPPLE (mVp-p) 300 0.1 e 0 0.01 D 0 1 2 3 4 5 6 7 8 9 10 11 12 r INTEGRATION SETTLING (IN DECIMAL) e w o P Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
11 - 8
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
