Datasheet AD8317 (Analog Devices) - 9
Description1 MHz TO 10 GHz, 50 dB Log Detector / Controller
Pages / Page20 / 9 — AD8317. Data Sheet. 2.00. 2.0. 1.75. 1.5. 1.50. 1.0. 1.25. 0.5. (V). …
RevisionC
File Format / SizePDF / 875 Kb
AD8317. Data Sheet. 2.00. 2.0. 1.75. 1.5. 1.50. 1.0. 1.25. 0.5. (V). 1.00. R (. RRO. 0.75. –0.5. 0.50. –1.0. 0.25. –1.5. –2.0
AD8317 Data Sheet 2.00 2.0 1.75 1.5 1.50 1.0 1.25 0.5 (V) 1.00 R ( RRO 0.75 –0.5 0.50 –1.0 0.25 –1.5 –2.0
AD8317 Data Sheet 2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 B) B) d d (V) (V) 1.00 R ( 1.00 0 R ( UT 0 UT O O V RRO V RRO E E 0.75 –0.5 0.75 –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0 –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10
009
012
P P IN (dBm)
05541-
IN (dBm)
05541- Figure 9. VOUT and Log Conformance vs. Input Amplitude at 900 MHz, Figure 12. VOUT and Log Conformance vs. Input Amplitude at 3.6 GHz, Multiple Devices, RTADJ = 18 kΩ Multiple Devices, RTADJ = 8 kΩ
2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 B) B) d d (V) (V) 1.00 R ( R ( UT 0 1.00 UT 0 O O V RRO V RRO E 0.75 –0.5 E 0.75 –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0
010
013
–60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 PIN (dBm)
05541-
PIN (dBm)
05541- Figure 10. VOUT and Log Conformance vs. Input Amplitude at 1.9 GHz, Figure 13. VOUT and Log Conformance vs. Input Amplitude at 5.8 GHz, Multiple Devices, RTADJ = 8 kΩ Multiple Devices, RTADJ = 500 Ω
1
0 –2.0
1 0
014
05541-
IN (dBm) PIN (dBm)
05541- Figure 11. VOUT and Log Conformance vs. Input Amplitude at 2.2 GHz, Figure 14. VOUT and Log Conformance vs. Input Amplitude at 8.0 GHz, Multiple Devices, RTADJ = 8 kΩ Multiple Devices, RTADJ = Open, Error Calculated from PIN = −34 dBm to PIN = −16 dBm Rev. C | Page 8 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8317 BASIC CONNECTIONS INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE MEASUREMENT MODE SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE CONTROLLER MODE OUTPUT FILTERING OPERATION BEYOND 8 GHz EVALUATION BOARD DIE INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
