Datasheet AD8317 (Analog Devices) - 10
Description1 MHz TO 10 GHz, 50 dB Log Detector / Controller
Pages / Page20 / 10 — Data Sheet. AD8317. 10000. j0.5. –60dBm. H V/. j0.2. (n Y 1000. IT S. …
RevisionC
File Format / SizePDF / 875 Kb
Data Sheet. AD8317. 10000. j0.5. –60dBm. H V/. j0.2. (n Y 1000. IT S. –40dBm. RF OFF. 0.2. 0.5. L A R. –20dBm. –10dBm. 100MHz. 100. PEC. –j0.2. 900MHz. ISE S O
Data Sheet AD8317 10000 j0.5 –60dBm H V/ j0.2 (n Y 1000 IT S –40dBm RF OFF 0.2 0.5 L A R –20dBm –10dBm 100MHz 100 PEC –j0.2 900MHz ISE S O
Data Sheet AD8317 j1 10000 j0.5 j2 z) –60dBm H V/ j0.2 (n Y 1000 IT S –40dBm N RF OFF E 0 D 0.2 0.5 1 2 L A R –20dBm T –10dBm 100MHz 100 PEC –j0.2 900MHz ISE S O 0dBm 1900MHz N
8 01 1-
8000MHz 2200MHz –j0.5 –j2
54 05
10 3600MHz 1k 10k 100k 1M 10M START FREQUENCY = 0.05GHz –j1 FREQUENCY (Hz) STOP FREQUENCY = 10GHz
15 0
5800MHz 10000MHz
5541- 0 Figure 15. Input Impedance vs. Frequency; No Termination Resistor on INHI Figure 18. Noise Spectral Density of Output; CLPF = Open (Impedance De-Embedded to Input Pins), Z0 = 50 Ω
10000 ∆ : 1.86V @ : 1.69V ) / Hz V n Y ( 1000 IT NS DE RAL T C E 100 P 3 S E IS NO
9 17 0 01 1- 1- 54 54 05
4
05
10 Ch3 500mV Ch4 200mV M4.00µs A Ch3 620mV 1k 10k 100k 1M 10M T 12.7560µs FREQUENCY (Hz)
Figure 16. Power-On/Power-Off Response Time; VPOS = 3.0 V; Figure 19. Noise Spectral Density of Output Buffer (from CLPF to VOUT); Input AC-Coupling Capacitors = 10 pF; CLPF = Open CLPF = 0.1 μF
2.00 2.0 1.75 1.5 1.50 1.0 CH1 RISE 10.44ns 1.25 0.5 ) B) CH1 FALL d (V 6.113ns T 1.00 R ( 0 OUV RO R 0.75 E –0.5 0.50 –1.0
6 -01
0.25 3.3V –1.5
541
3.0V
05
3.6V CH1 200mV M20.0ns A CH1 1.40V 0 –2.0
0
T 943.600ns
02
–65 –55 –45 –35 –25 –15 –5 5 15
41-
PIN (dBm)
055 Figure 17. VOUT Pulse Response Time; Pulsed RF Input 0.1 GHz, −10 dBm; Figure 20. Output Voltage Stability vs. Supply Voltage at 1.9 GHz CLPF = Open; RLOAD = 150 Ω When VPOS Varies by 10% Rev. C | Page 9 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8317 BASIC CONNECTIONS INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE MEASUREMENT MODE SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE CONTROLLER MODE OUTPUT FILTERING OPERATION BEYOND 8 GHz EVALUATION BOARD DIE INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
