Datasheet AD8315 (Analog Devices) - 6
Description50 dB GSM PA Controller
Pages / Page23 / 6 — Data Sheet. AD8315. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. …
RevisionD
File Format / SizePDF / 508 Kb
Data Sheet. AD8315. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
Data Sheet AD8315 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
Stresses at or above those listed under Absolute Maximum
Table 3.
Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Supply Voltage VPOS 5.5 V or any other conditions above those indicated in the operational Temporary Overvoltage VPOS section of this specification is not implied. Operation beyond (100 cycles, 2 sec duration, ENBL Low) 6.3 V the maximum operating conditions for extended periods may VAPC, VSET, ENBL 0 V, VPOS affect product reliability. RFIN 17 dBm
ESD CAUTION
Equivalent Voltage 1.6 V rms Internal Power Dissipation 60 mW θJA (MSOP) 200°C/W θJA (LFCSP, Paddle Soldered) 80°C/W θJA (LFCSP, Paddle Not Soldered) 200°C/W Maximum Junction Temperature 125°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering 60 sec) MSOP 300°C LFCSP 240°C Rev. D | Page 5 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC THEORY CONTROLLER-MODE LOG AMPS CONTROL LOOP DYNAMICS Example PRACTICAL LOOP A NOTE ABOUT POWER EQUIVALENCY BASIC CONNECTIONS RANGE ON VSET AND RFIN TRANSIENT RESPONSE MOBILE HANDSET POWER CONTROL EXAMPLE ENABLE AND POWER-ON INPUT COUPLING OPTIONS USING THE CHIP SCALE PACKAGE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
