Datasheet AD641 (Analog Devices) - 7
Description250 MHz Demodulating Logarithmic Amplifier
Pages / Page12 / 7 — STANDARD. 5962-95598. MICROCIRCUIT DRAWING
File Format / SizePDF / 76 Kb
STANDARD 5962-95598 MICROCIRCUIT DRAWING
Device types 01, 02 Case outline R Terminal Terminal symbol number 1 SIGNAL –INPUT (SIG –IN) 2 ATTENUATOR LOW (ATN LO) 3 ATTENUATOR COMMON (ATN COM) 4 ATTENUATOR COMMON (ATN COM) 5 ATTENUATOR INPUT (ATN IN) 6 BALANCE LIMITER 1 (BL1) 7 NEGATIVE POWER SUPPLY (-VS) 8 INTERNAL TEMPERATURE COMPENSATION (ITC) 9 BALANCE LIMITER 2 (BL2) 10 SIGNAL –OUTPUT (SIG –OUT) 11 SIGNAL +OUTPUT (SIG +OUT) 12 POSITIVE POWER SUPPLY (+VS) 13 LOGARITHMIC COMMON (LOG COM) 14 LOGARITHMIC OUTPUT (LOG OUT) 15 GAIN RESISTOR 2 (RG2) 16 GAIN RESISTOR 0 (RG0) 17 GAIN RESISTOR 1 (RG1) 18 CIRCUIT COMMON (CKT COM) 19 ATTENUATOR OUTPUT (ATN OUT) 20 SIGNAL +INPUT (SIG +IN) FIGURE 1. Terminal connections.
STANDARD
SIZE
5962-95598 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 D 7 DSCC FORM 2234 APR 97
