Datasheet AD640 (Analog Devices) - 3
DescriptionDC-Coupled Demodulating 120 MHz Logarithmic Amplifier
Pages / Page12 / 3 — STANDARD. 5962-90955. MICROCIRCUIT DRAWING
File Format / SizePDF / 82 Kb
STANDARD 5962-90955 MICROCIRCUIT DRAWING
1.3 Absolute maximum ratings. 1/ Supply voltage (VS) ... 7.5 V Input voltage (SIG –IN and SIG +IN pins to CKT COM pin) .. -3.0 V to +300 mV Attenuator input voltage (ATN IN pin to ATN COM pins) ... 3.0 V Storage temperature range ... -65C to +150C Lead temperature (soldering, 60 seconds) .. +300C Thermal resistance, junction-to-case (JC) .. See MIL-STD-1835 Thermal resistance, junction-to-ambient (JA) ... 95C/W 1.4 Recommended operating conditions. Supply voltage range (VS) ... 4.5 V to 7.5 V Ambient operating temperature range (TA) ... -55C to +125C 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those cited in the solicitation or contract. DEPARTMENT OF DEFENSE SPECIFICATION MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. DEPARTMENT OF DEFENSE STANDARDS MIL-STD-883 - Test Method Standard Microcircuits. MIL-STD-1835 - Interface Standard Electronic Component Case Outlines. DEPARTMENT OF DEFENSE HANDBOOKS MIL-HDBK-103 - List of Standard Microcircuit Drawings. MIL-HDBK-780 - Standard Microcircuit Drawings. (Copies of these documents are available online at http://quicksearch.dla.mil or from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) 2.2 Order of precedence. In the event of a conflict between the text of this drawing and the references cited herein, the text of this drawing takes precedence. Nothing in this document, however, supersedes applicable laws and regulations unless a specific exemption has been obtained. ______ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability.
STANDARD
SIZE
5962-90955 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 D 3 DSCC FORM 2234 APR 97
