Datasheet LTC6902 (Analog Devices) - 2
Description | Multiphase Oscillator with Spread Spectrum Frequency Modulation |
Pages / Page | 16 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL … |
File Format / Size | PDF / 213 Kb |
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL CHARACTERISTICS The
LTC6902
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
Supply Voltage (V+) to GND ..– 0.3V to 6V ORDER Voltage On Any Pin TOP VIEW PART NUMBER (Referred to GND) ... – 0.3V to (V+ + 0.3V) V+ 1 10 SET Operating Temperature Range (Note 9) DIV 2 9 MOD LTC6902CMS PH 3 8 GND LTC6902C .. – 40°C to 85°C LTC6902IMS OUT1 4 7 OUT4 OUT2 5 6 OUT3 LTC6902I .. – 40°C to 85°C MS PACKAGE MS PART MARKING Specified Temperature Range (Note 10) 10-LEAD PLASTIC MSOP LTC6902C .. – 40°C to 85°C TJMAX = 150°C, θJA = 250°C/W LTK2 LTC6902I .. – 40°C to 85°C LTK3 Storage Temperature Range ... – 65°C to 150°C Consult LTC Marketing for parts specified with wider operating temperature ranges. Lead Temperature (Soldering, 10 sec).. 300°C
C. V+ = 2.7V to 5.5V, RL= 5k, CL = 5pF, Pin 3 (PH) = 0V (2-phase, M = 1) unless otherwise specified. Pin 9 (MOD) is at 0V unless otherwise specified. RSET is defined as a resistor connected from the SET pin to the V+ pin. RMOD is defined as a resistor connected from the MOD pin to the V+ pin. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
∆fOUT Frequency Accuracy (Notes 2, 3) V+ = 5V 5kHz ≤ fOUT ≤ 10MHz ±0.5 ±1.5 % 1kHz ≤ fOUT ≤ 5kHz ±2.0 % 10MHz ≤ fOUT ≤ 20MHz ● ±3.0 ±4.0 % 5kHz ≤ fOUT ≤ 10MHz, LTC6902C ● ±2.0 % 5kHz < fOUT ≤ 10MHz, LTC6902I ● ±2.5 % V+ = 2.7V 5kHz ≤ fOUT ≤ 10MHz ±0.5 ±1.5 % 1kHz ≤ fOUT ≤ 5kHz ±2.0 % 5kHz ≤ fOUT ≤ 10MHz, LTC6902C ● ±2.0 % 5kHz ≤ fOUT ≤ 10MHz, LTC6902I ● ±2.5 % RSET Frequency Setting Resistor Range ∆fOUT < 1.5%, V+ = 5V ● 20 400 kΩ ∆fOUT < 1.5%, V+ = 2.7V ● 20 400 kΩ ∆fOUT/∆T Frequency Drift Over Temperature RSET = 63.2k ● ±0.004 %/°C (Note 3) ∆fOUT/∆V Frequency Drift Over Supply (Note 3) V+ = 2.7V to 5V, RSET = 63.2k ● 0.04 0.12 %/V Timing Jitter (Note 4) 20k ≤ RSET ≤ 400k Pin 2 = V+ (N = 100) 0.1 % Pin 2 = Open (N = 10) 0.2 % Pin 2 = 0V (N = 1) 0.6 % Long-Term Stability of 300 ppm/√kHr Output Frequency Duty Cycle (Note 5) Pin 2 = V+ or Open (N = 100 or 10) Pin 3 = 0V (2-Phase, M = 1) ● 49.0 50.0 51.0 % Pin 3 = Open (3-Phase, M = 3) ● 32.3 33.3 34.3 % Pin 3 = V+ (4-Phase, M = 4) ● 49.0 50.0 51.0 % Pin 2 = 0V (N = 1) Pin 3 = 0V (2-Phase, M = 1) ● 45.0 50.0 55.0 % Pin 3 = Open (3-Phase, M = 3) ● 32.3 33.3 34.3 % Pin 3 = V+ (4-Phase, M = 4) ● 49.0 50.0 51.0 % 6902f 2
