Datasheet ADA4897-2-KGD (Analog Devices) - 8
Description1 nV/√Hz, Low Power Operational Amplifier
Pages / Page10 / 8 — ADA4897-2-KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS Table 4. ESD …
RevisionC
File Format / SizePDF / 208 Kb
ADA4897-2-KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS Table 4. ESD CAUTION. Parameter. Rating
ADA4897-2-KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 4 ESD CAUTION Parameter Rating
ADA4897-2-KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 4. ESD CAUTION Parameter Rating
Supply Voltage 12.6 V Common-Mode Input Voltage ±VS ± 0.5 V Differential Input Voltage ±1.8 V Storage Temperature Range –65°C to +125°C Operating Temperature Range –40°C to +125°C Junction Temperature 150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 8 of 10 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V SUPPLY +5 V SUPPLY +3 V SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
