Datasheet PCA9685 (NXP) - 4
ManufacturerNXP
Description16-channel, 12-bit PWM Fm+ I2C-bus LED controller
Pages / Page52 / 4 — NXP Semiconductors. PCA9685. 16-channel, 12-bit PWM Fm+ I2C-bus LED …
Revision4.0
File Format / SizePDF / 409 Kb
NXP Semiconductors. PCA9685. 16-channel, 12-bit PWM Fm+ I2C-bus LED controller. 4. Ordering. information. Table 1
NXP Semiconductors PCA9685 16-channel, 12-bit PWM Fm+ I2C-bus LED controller 4 Ordering information Table 1
link to page 4
NXP Semiconductors PCA9685 16-channel, 12-bit PWM Fm+ I2C-bus LED controller 4. Ordering information Table 1. Ordering information Type number Topside mark Package Name Description Version
PCA9685PW PCA9685PW TSSOP28 plastic thin shrink small outline package; SOT361-1 28 leads; body width 4.4 mm PCA9685PW/Q900[1] PCA9685PW TSSOP28 plastic thin shrink small outline package; SOT361-1 28 leads; body width 4.4 mm PCA9685BS P9685 HVQFN28 plastic thermal enhanced very thin quad flat SOT788-1 package; no leads; 28 terminals; body 6  6  0.85 mm [1] PCA9685PW/Q900 is AEC-Q100 compliant. Contact
i2c.support@nxp.com
for PPAP.
4.1 Ordering options Table 2. Ordering options Type number Orderable Package Packing method Minimum Temperature part number order quantity
PCA9685PW PCA9685PW,118 TSSOP28 REEL 13" Q1/T1 2500 Tamb = 40 C to +85 C *STANDARD MARK SMD PCA9685PW/Q900 PCA9685PW/Q900,118 TSSOP28 REEL 13" Q1/T1 2500 Tamb = 40 C to +85 C *STANDARD MARK SMD PCA9685BS PCA9685BS,118 HVQFN28 REEL 13" Q1/T1 4000 Tamb = 40 C to +85 C *STANDARD MARK SMD PCA9685 All information provided in this document is subject to legal disclaimers. © NXP Semiconductors N.V. 2015. All rights reserved.
Product data sheet Rev. 4 — 16 April 2015 4 of 52
Document Outline 1. General description 2. Features and benefits 3. Applications 4. Ordering information 4.1 Ordering options 5. Block diagram 6. Pinning information 6.1 Pinning 6.2 Pin description 7. Functional description 7.1 Device addresses 7.1.1 Regular I2C-bus slave address 7.1.2 LED All Call I2C-bus address 7.1.3 LED Sub Call I2C-bus addresses 7.1.4 Software Reset I2C-bus address 7.2 Control register 7.3 Register definitions 7.3.1 Mode register 1, MODE1 7.3.1.1 Restart mode 7.3.2 Mode register 2, MODE2 7.3.3 LED output and PWM control 7.3.4 ALL_LED_ON and ALL_LED_OFF control 7.3.5 PWM frequency PRE_SCALE 7.3.6 SUBADR1 to SUBADR3, I2C-bus subaddress 1 to 3 7.3.7 ALLCALLADR, LED All Call I2C-bus address 7.4 Active LOW output enable input 7.5 Power-on reset 7.6 Software reset 7.7 Using the PCA9685 with and without external drivers 8. Characteristics of the I2C-bus 8.1 Bit transfer 8.1.1 START and STOP conditions 8.2 System configuration 8.3 Acknowledge 9. Bus transactions 10. Application design-in information 11. Limiting values 12. Static characteristics 13. Dynamic characteristics 14. Test information 15. Package outline 16. Handling information 17. Soldering of SMD packages 17.1 Introduction to soldering 17.2 Wave and reflow soldering 17.3 Wave soldering 17.4 Reflow soldering 18. Abbreviations 19. Revision history 20. Legal information 20.1 Data sheet status 20.2 Definitions 20.3 Disclaimers 20.4 Trademarks 21. Contact information 22. Contents
