Datasheet MAX4162, MAX4163, MAX4164 (Maxim) - 5
Manufacturer | Maxim |
Description | UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps |
Pages / Page | 13 / 5 — UCSP, Micropower, Single-Supply, 10V,. Rail-to-Rail I/O Op Amps. … |
File Format / Size | PDF / 331 Kb |
UCSP, Micropower, Single-Supply, 10V,. Rail-to-Rail I/O Op Amps. MAX4162/MAX4163/MAX4164
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps MAX4162/MAX4163/MAX4164 Typical Operating Characteristics (continued)
(VDD = 5V, VSS = 0V, VCM = VDD/2, TA = +25°C, unless otherwise noted.)
INPUT OFFSET VOLTAGE INPUT OFFSET VOLTAGE VARIATION POWER-SUPPLY REJECTION RATIO vs. TEMPERATURE vs. COMMON-MODE VOLTAGE vs. FREQUENCY
1000 6 130 AV = 1 750 4 MAX4162-04 MAX4162-05 MAX4162-08 2 110 500 0 90 250 -2 µV) ( (µV) 0 -4 70 V OS V OS PSRR (dB) -250 -6 50 -8 -500 -10 30 -750 -12 -1000 -14 10 -40 -20 0 20 40 60 80 100 -0.5 0.5 1.5 2.5 3.5 4.5 5.5 0.1 1 10 100 1k 10k 100k 1M TEMPERATURE (°C) COMMON-MODE VOLTAGE (V) FREQUENCY (Hz)
POWER-SUPPLY REJECTION RATIO COMMON-MODE REJECTION OPEN-LOOP GAIN vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
130 120 160 V 110 DD = 3V OR 5V MAX4162-10 MAX4162-09 140 MAX4162-11 100 110 RL = 100kΩ 90 120 90 80 100 R 70 L = 10kΩ 70 60 80 PSRR (dB) 50 60 40 50 OPEN-LOOP GAIN (dB) 30 40 COMMON-MODE REJECTION (dB) V 30 20 DD = 3V OR 5V V 20 10 CM = -0.25V TO VDD + 0.25V 10 0 0 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 TEMPERATURE ( TEMPERATURE ( °C) °C) TEMPERATURE (°C)
OUTPUT IMPEDANCE COMMON-MODE INPUT CAPACITANCE SHORT-CIRCUIT OUTPUT CURRENT vs. FREQUENCY vs. COMMON-MODE VOLTAGE vs. TEMPERATURE
10,000 2.00 40 AV = 1 VDD = 3V OR 5V 35 MAX4162-12a MAX4162-13 MAX4162-12b SHORT TO EITHER SUPPLY RAIL 1000 ) Ω 30 1.75 25 100 1.50 20 10 15 OUTPUT IMPEDANCE ( 10 1.25 1 SHORT-CIRCUIT OUTPUT CURRENT (mA) 5 COMMON-MODE INPUT CAPACITANCE (pF) 0.1 1.00 0 0.1 1 10 100 1k 10k 100k 1M 0 1.25 2.50 3.75 5.00 -40 -20 0 20 40 60 80 100 FREQUENCY (Hz) COMMON-MODE VOLTAGE (V) TEMPERATURE (°C)
_______________________________________________________________________________________ 5
