Datasheet MAX4162, MAX4163, MAX4164 (Maxim) - 6
Manufacturer | Maxim |
Description | UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps |
Pages / Page | 13 / 6 — UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps. Typical … |
File Format / Size | PDF / 331 Kb |
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps. Typical Operating Characteristics (continued)
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps Typical Operating Characteristics (continued)
(VDD = 5V, VSS = 0V, VCM = VDD/2, TA = +25°C, unless otherwise noted.)
MAXIMUM OUTPUT VOLTAGE MAXIMUM OUTPUT VOLTAGE MINIMUM OUTPUT VOLTAGE vs. TEMPERATURE vs. LOAD CURRENT vs. LOAD CURRENT (VDD = 5V)
300 300 100 VDD = 3V OR 5V VDD = 3V OR 5V V 90 DD = 5V MAX4162-14 LOAD TO V MAX4162-15 LOAD TO V MAX4162-16 250 DD/2 250 DD/2 LOAD TO V 80 DD/2 RL = 5kΩ 70 200 (mV) 200 (mV) (mV) 60 150 150 50 OUT(MAX) OUT(MAX) RL = 10kΩ - V V OUT(MIN) - V 40 100 V DD 100 V DD 30 20 50 50 R 10 L = 100kΩ 0 0 0 0 0.4 0.8 1.2 1.6 2.0 0 0.4 0.8 1.2 1.6 2.0 -40 -20 0 20 40 60 80 100 LOAD CURRENT (mA) LOAD CURRENT (mA) TEMPERATURE (°C)
MINIMUM OUTPUT VOLTAGE MAXIMUM OUTPUT VOLTAGE MINIMUM OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE (VDD = 5V) (V (V DD = 3V) DD = 3V)
140 60 90 V V V DD = 5V DD = 3V 80 DD = 3V MAX4162-17 MAX4162-18 MAX4162-19 120 LOAD TO V LOAD TO V LOAD TO V DD/2 RL = 5kΩ 50 DD/2 DD/2 70 R R L = 5kΩ 100 L = 5kΩ 40 60
MAX4162/MAX4163/MAX4164
(mV) (mV) 80 (mV) R 50 L = 10kΩ R 30 R L = 10kΩ OUT(MAX) L = 10kΩ 40 60 V OUT(MIN) - V V OUT(MIN) 20 30 V DD 40 20 20 R 10 L = 100kΩ R RL = 100kΩ 10 L = 100kΩ 0 0 0 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
NOISE VOLTAGE DENSITY NOISE VOLTAGE DENSITY TOTAL HARMONIC DISTORTION vs. COMMON-MODE VOLTAGE vs. FREQUENCY PLUS NOISE vs. FREQUENCY
120 100 1 A 90 V = 1 MAX4162-20 MAX4162-21a MAX4162-21b RL = 100kΩ 100 √Hz) 100Hz 80 √Hz ) 70 80 1kHz 0.1 VP-P = 4.99V 60 60 10kHz 50 40 THD + N (%) VP-P = 1V 40 0.01 30 NOISE VOLTAGE DENSITY (nV/ 20 20 NOISE VOLTAGE DENSITY (nV/ 10 0 0 0.001 -0.5 0.5 1.5 2.5 3.5 4.5 5.5 10 100 1k 10k 100k 1M 10 100 1k 10k COMMON-MODE VOLTAGE (V) FREQUENCY (Hz) FREQUENCY (Hz)
6 _______________________________________________________________________________________
