Datasheet MIC7211, MIC7221 (Microchip) - 4
ManufacturerMicrochip
DescriptionIttyBitty Rail-to-Rail Input Comparator
Pages / Page7 / 4 — Micrel, Inc. MIC7211/7221 AC Electrical Characteristics
Revision11-09-2015
File Format / SizePDF / 351 Kb
Micrel, Inc MIC7211/7221 AC Electrical Characteristics
VV– = 0V, VCM = VOUT = VV+/2; TJ = 25°C, bold values indicate –40°C ≤ TJ ≤ +85°C; Note 7; unless noted
Symbol Parameter Condition Min Typ Max Units Rise Time tRISE VV+ = 5.0V, f = 10kHz, CLOAD = 50pF overdrive = 10mV, Note 9 75 ns Fall Time tFALL VV+ = 5.0V, f = 10kHz, CLOAD = 50pF overdrive = 10mV, Note 9 70 ns Propagation Delay-High to Low tPHL VV+ = 2.2V, f = 10kHz, CLOAD = 50pF overdrive = 10mV, Note 9 10 µs VV+ = 2.2V, f = 10kHz, CLOAD = 50pF overdrive = 100mV, Note 9 6.0 µs VV+ = 5.0V, f = 10kHz, CLOAD = 50pF overdrive = 10mV, Note 9 13 µs VV+ = 5.0V, f = 10kHz, CLOAD = 50pF overdrive = 100mV, Note 9 5 µs Propagation Delay-Low to High tPLH VV+ = 2.2V, f = 10kHz, CLOAD = 50pF overdrive = 10mV, Note 9 13.5 µs VV+ = 2.2V, f = 10kHz, CLOAD = 50pF overdrive = 100mV, Note 9 4.0 µs VV+ = 5.0V, f = 10kHz, CLOAD = 50pF overdrive = 10mV, Note 9 11.5 µs VV+ = 5.0V, f = 10kHz, CLOAD = 50pF overdrive = 100mV, Note 9 3.0 µs Note 1. Exceeding the absolute maximum rating may damage the device.
Note 2. The device is not guaranteed to function outside its operating rating.
Note 3. I/O pin voltage is any external voltage to which an input or output is referenced.
Note 4. The maximum allowable power dissipation is a function of the maximum junction temperature, TJ(max); the junction-to-ambient thermal
resistance, θJA; and the ambient temperature, TA. The maximum allowable power dissipation at any ambient temperature is calculated using
PD(max) = (TJ(max) – TA) ÷ θJA. Exceeding the maximum allowable power dissipation will result in excessive die temperature. Note 5. Thermal resistance, θJA, applies to a part soldered on a printed circuit board.
Note 6. Devices are ESD sensitive. Handling precautions recommended.
Note 7. All limits guaranteed by testing on statistical analysis. Note 8. Continuous short circuit may exceed absolute maximum TJ under some conditions. Note 9. The MIC7221 requires 5kΩ pull-up resistor. Partial Functional Diagrams
V+ V+ OUT OUT V– V– MIC7211 Push-Pull Output October 2009 MIC7221 Open-Drain Output 4 M9999-100909
