Datasheet MCP3202 (Microchip)
ManufacturerMicrochip
Description2.7V Dual Channel 12-Bit A/D Converter with SPI Serial Interface
Pages / Page34 / 1 — MCP3202. 2.7V Dual Channel 12-Bit A/D Converter. with SPI Serial …
MCP3202. 2.7V Dual Channel 12-Bit A/D Converter. with SPI Serial Interface. Features. Description. Applications. Package Types
Datasheet MCP3202 Microchip
MCP3202 2.7V Dual Channel 12-Bit A/D Converter with SPI Serial Interface Features Description
• 12-bit resolution The MCP3202 is a successive approximation 12-bit • ±1 LSB maximum DNL analog-to-digital (A/D) converter with on-board sample • ±1 LSB maximum INL (MCP3202-B) and hold circuitry. • ±2 LSB maximum INL (MCP3202-C) The MCP3202 is programmable to provide a single • Analog inputs programmable as single-ended or pseudo-differential input pair or dual single-ended pseudo-differential pairs inputs. Differential Nonlinearity (DNL) is specified at ±1 LSB, and Integral Nonlinearity (INL) is offered in • On-chip sample and hold ±1 LSB (MCP3202-B) and ±2 LSB (MCP3202-C) • SPI Serial Interface (Modes 0,0 and 1,1) versions. • Single supply operation: 2.7V-5.5V Communication with the device is done using a simple • 100 ksps maximum sampling rate at VDD = 5V serial interface compatible with the SPI protocol. The • 50 ksps maximum sampling rate at VDD = 2.7V device is capable of conversion rates of up to 100 ksps • Low power CMOS technology at 5V and 50 ksps at 2.7V. • 500 nA typical standby current, 5 µA maximum The MCP3202 operates over a broad voltage range, • 550 µA maximum active current at 5V 2.7V to 5.5V. Low-current design permits operation with • Industrial temp range: -40°C to +85°C typical standby and active currents of only 500 nA and 375 µA, respectively. • 8-pin MSOP, PDIP, SOIC and TSSOP packages The MCP3202 is offered in 8-pin MSOP, PDIP, TSSOP
Applications
and 150 mil SOIC packages. • Sensor Interface
Package Types
• Process Control • Data Acquisition
PDIP, MSOP, SOIC, TSSOP
• Battery Operated Systems CS/SHDN 1
MC
8 VDD/VREF
Functional Block Diagram
CH0 2
P3
7 CLK
202
CH1 3 6 DOUT V V DD SS V 4 5 SS DIN Input CH0 Channel DAC CH1 Mux Comparator Sample 12-Bit SAR and Hold Shift Control Logic Register CS/SHDN D CLK D IN OUT  1999-2011 Microchip Technology Inc. DS21034F-page 1 Document Outline MCP3202 - 2.7V Dual Channel 12-Bit A/D Converter with SPI Serial Interface Functional Block Diagram Package Types 1.0 Electrical Characteristics Absolute Maximum Ratings † FIGURE 1-1: Serial Timing. FIGURE 1-2: Test Circuits. 2.0 Typical Performance Characteristics FIGURE 2-1: Integral Nonlinearity (INL) vs. Sample Rate. FIGURE 2-2: Integral Nonlinearity (INL) vs. VDD. FIGURE 2-3: Integral Nonlinearity (INL) vs. Code (Representative Part). FIGURE 2-4: Integral Nonlinearity (INL) vs. Sample Rate (VDD = 2.7V). FIGURE 2-5: Integral Nonlinearity (INL) vs. VDD. FIGURE 2-6: Integral Nonlinearity (INL) vs. Code (Representative Part, VDD = 2.7V). FIGURE 2-7: Integral Nonlinearity (INL) vs. Temperature. FIGURE 2-8: Differential Nonlinearity (DNL) vs. Sample Rate. FIGURE 2-9: Differential Nonlinearity (DNL) vs. VDD. FIGURE 2-10: Integral Nonlinearity (INL) vs. Temperature (VDD = 2.7V). FIGURE 2-11: Differential Nonlinearity (DNL) vs. Sample Rate (VDD = 2.7V). FIGURE 2-12: Differential Nonlinearity (DNL) vs. VDD. FIGURE 2-13: Differential Nonlinearity (DNL) vs. Code (Representative Part). FIGURE 2-14: Differential Nonlinearity (DNL) vs. Temperature. FIGURE 2-15: Gain Error vs. VDD. FIGURE 2-16: Differential Nonlinearity (DNL) vs. Code (Representative Part, VDD = 2.7V). FIGURE 2-17: Differential Nonlinearity (DNL) vs. Temperature (VDD = 2.7V). FIGURE 2-18: Offset Error vs. VDD. FIGURE 2-19: Gain Error vs. Temperature. FIGURE 2-20: Signal-to-Noise Ratio (SNR) vs. Input Frequency. FIGURE 2-21: Total Harmonic Distortion (THD) vs. Input Frequency. FIGURE 2-22: Offset Error vs. Temperature. FIGURE 2-23: Signal-to-Noise and Distortion (SINAD) vs. Input Frequency. FIGURE 2-24: Signal-to-Noise and Distortion (SINAD) vs. Signal Level. FIGURE 2-25: Effective Number of Bits (ENOB) vs. VDD. FIGURE 2-26: Spurious Free Dynamic Range (SFDR) vs. Input Frequency. FIGURE 2-27: Frequency Spectrum of 10 kHz input (Representative Part). FIGURE 2-28: Effective Number of Bits (ENOB) vs. Input Frequency. FIGURE 2-29: Power Supply Rejection (PSR) vs. Ripple Frequency. FIGURE 2-30: Frequency Spectrum of 1 kHz input (Representative Part, VDD = 2.7V). FIGURE 2-31: IDD vs. VDD. FIGURE 2-32: IDD vs. Clock Frequency. FIGURE 2-33: IDD vs. Temperature. FIGURE 2-34: IDDS vs. VDD. FIGURE 2-35: IDDS vs. Temperature. FIGURE 2-36: Analog Input leakage current vs. Temperature. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Inputs (CH0/CH1) 3.2 Chip Select/Shutdown (CS/SHDN) 3.3 Serial Clock (CLK) 3.4 Serial Data Input (DIN) 3.5 Serial Data Output (DOUT) 4.0 Device Operation 4.1 Analog Inputs 4.2 Digital Output Code EQUATION 4-1: FIGURE 4-1: Analog Input Model. FIGURE 4-2: Maximum Clock Frequency vs. Input Resistance (RS) to maintain less than a 0.1 LSB deviation in INL from nominal conditions. 5.0 Serial Communications 5.1 Overview TABLE 5-1: Configuration Bits for the MCP3202 FIGURE 5-1: Communication with the MCP3202 using MSB first format only. FIGURE 5-2: Communication with MCP3202 using LSB first format. 6.0 Applications Information 6.1 Using the MCP3202 with Microcontroller (MCU) SPI Ports FIGURE 6-1: SPI Communication using 8-bit segments (Mode 0,0: SCLK idles low). FIGURE 6-2: SPI Communication using 8-bit segments (Mode 1,1: SCLK idles high). 6.2 Maintaining Minimum Clock Speed 6.3 Buffering/Filtering the Analog Inputs FIGURE 6-3: The MCP601 Operational Amplifier is used to implement a 2nd order anti- aliasing filter for the signal being converted by the MCP3202. 6.4 Layout Considerations FIGURE 6-4: VDD traces arranged in a ‘Star’ configuration in order to reduce errors caused by current return paths. 7.0 Packaging Information 7.1 Package Marking Information Appendix A: Revision History Worldwide Sales and Service
