Datasheet LTC4308 (Analog Devices) - 7
Description | Low Voltage, Level Shifting Hot Swappable 2-Wire Bus Buffer with Stuck Bus Recovery |
Pages / Page | 16 / 7 — BLOCK DIAGRAM. Low Voltage Level Shifting 2-Wire Bus Buffer with Stuck … |
File Format / Size | PDF / 172 Kb |
BLOCK DIAGRAM. Low Voltage Level Shifting 2-Wire Bus Buffer with Stuck Bus Recovery
LTC4308
BLOCK DIAGRAM Low Voltage Level Shifting 2-Wire Bus Buffer with Stuck Bus Recovery
8mA VCC 8 CONNECT IBOOSTSDA SDAIN SDAOUT 6 7 SLEW RATE DETECTOR 100k CONNECT PRECHARGE PC_CONNECT 8mA 100k CONNECT IBOOSTSCL SCLIN SCLOUT 3 2 SLEW RATE DETECTOR + CONNECT 1.65V/1.6V – 1.35V/1.3V 30ms + TIMER + 0.6V – 1.65V/1.6V I – BOOSTSCL 1.35V/1.3V IBOOSTSDA + LOGIC 0.6V – READY 5 CONNECT PC_CONNECT ENABLE 1 + 0.6V – GND 95μs CONNECT 4 UVLO DELAY 4308 BD 4308f 7
