Datasheet LT5570 (Analog Devices) - 3
DescriptionFast Responding, 40MHz to 2.7GHz Mean-Squared Power Detector
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 275 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT5570
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C, VCC = 5V, EN = 5V, unless otherwise noted. Test circuits are shown in Figures 1 and 3. (Notes 2 and 3). PARAMETER CONDITIONS MIN TYP MAX UNITS fRF = 880MHz
RF Input Power Range CW Input; 1:4 Balun Matched into 50Ω Source –48 to 13 dBm Linear Dynamic Range (Note 5) ±1dB Linearity Error, TA = –40°C to 85°C 61 dB Output Slope 37.7 mV/dB Logarithmic Intercept –51.9 dBm Output Variation vs Temperature Normalized to Output at 25°C ±0.4 dB –40°C < TA < 85°C; PIN = –47dBm to 13dBm Deviation from CW Response 11dB Peak to Average Ratio (3-Carrier CDMA2K) 0.3 dB 12dB Peak to Average Ratio (4-Carrier WCDMA) 0.2 2nd Order Harmonic Distortion At RF Input; CW Input; PIN = 10dBm 60 dBc 3rd Order Harmonic Distortion At RF Input; CW Input; PIN = 10dBm 61 dBc
fRF = 2140MHz
RF Input Power Range CW Input; 1:4 Balun Matched into 50Ω Source –38 to 13 dBm Linear Dynamic Range (Note 5) ±1dB Linearity Error, TA = –40°C to 85°C 47 51 dB Output Slope 34.8 36.5 39.0 mV/dB Logarithmic Intercept –43.6 –40.6 –37.6 dBm Output Variation vs Temperature Normalized to Output at 25°C ±0.3 dB –40°C < TA < 85°C; PIN = –36dBm to 13dBm Deviation from CW Response 11dB Peak to Average Ratio (3-Carrier CDMA2K) 0.1 dB 12dB Peak to Average Ratio (4-Carrier WCDMA) 0.2 dB
fRF = 2700MHz
RF Input Power Range CW Input; 1:4 Balun Matched into 50Ω Source –35 to 13 dBm Linear Dynamic Range (Note 5) ±1dB Linearity Error, TA = –40°C to 85°C 48 dB Output Slope 36.4 mV/dB Logarithmic Intercept –38.5 dBm Output Variation vs Temperature Normalized to Output at 25°C ±0.2 dB –40°C < TA < 85°C; PIN = –31dBm to 13dBm Deviation from CW Response 11dB Peak to Average Ratio (3-Carrier CDMA2K) 0.1 dB 12dB Peak to Average Ratio (4-Carrier WCDMA) 0.5
Output
Output DC Voltage No RF Signal Present 0.1 V Output Impedance 100 Ω Sourcing/Sinking 5/2.5 mA Rise Time 0.2V to 1.6V, 10% to 90%, C1 = 22nF, fRF = 2140MHz 0.5 μS Fall Time 1.6V to 0.2V, 90% to 10%, C1 = 22nF, fRF = 2140MHz 8 μS 5570f 3
