Datasheet LT5581 (Analog Devices) - 3
Description6GHz RMS Power Detector with 40dB Dynamic Range
Pages / Page18 / 3 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 640 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating temperature
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating temperature
LT5581
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C, VCC = 3.3V, EN = 3.3V, unless otherwise noted (Note 2). Test circuit is shown in Figure 1. PARAMETER CONDITIONS MIN TYP MAX UNITS
2nd Order Harmonic Distortion At RF Input; CW Input; PIN = 0dBm –57 dBc 3rd Order Harmonic Distortion At RF Input; CW Input; PIN = 0dBm –52 dBc
fRF = 880MHz
RF Input Power Range Externally Matched to 50Ω Source –34 to 6 dBm Linear Dynamic Range, CW (Note 3) ±1dB Linearity Error 40 dB Linear Dynamic Range, EDGE (Note 3) ±1dB Linearity Error; EDGE 3π/8-Shifted 8PSK 40 dB Output Slope 31 mV/dB Logarithmic Intercept (Note 5) –42 dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±1 dB PIN = –34 to +6dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±0.5 dB PIN = –27 to –10dBm Deviation from CW Response, Pin = –34 to +6dBm EDGE 3π/8 Shifted 8PSK ±0.1 dB
fRF = 2140MHz
RF Input Power Range Externally Matched to 50Ω Source –34 to 6 dBm Linear Dynamic Range, CW (Note 3) ±1dB Linearity Error 43 dB Linear Dynamic Range, WCDMA (Note 3) ±1dB Linearity Error; 4-Carrier WCDMA 37 dB Output Slope 31 mV/dB Logarithmic Intercept (Note 5) –42 dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±1 dB PIN = –34 to 6dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±0.5 dB PIN = –27 to –10dBm Maximum Deviation from CW Response WCDMA 1-Carrier Uplink ±0.1 dB PIN = –34 to –4dBm WCDMA 64-Channel 4-Carrier Downlink ±0.5 dB
fRF = 2600MHz
RF Input Power Range Externally Matched to 50Ω Source –34 to 6 dBm Linear Dynamic Range, CW (Note 3) ±1dB Linearity Error 40 dB Output Slope 31 mV/dB Logarithmic Intercept (Note 5) –42 dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±1 dB PIN = –34 to +6dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±0.5 dB PIN = –27 to –10dBm Maximum Deviation from CW Response WiMAX OFDMA Preamble ±0.1 dB PIN = –34 to 2dBm WiMAX OFDM Burst ±0.5 dB
fRF = 3500MHz
RF Input Power Range Externally Matched to 50Ω Source –30 to 6 dBm Linear Dynamic Range, CW (Note 3) ±1dB Linearity Error 36 dB Output Slope 31 mV/dB Logarithmic Intercept (Note 5) –41 dBm Output Variation vs Temperature Normalized to Output at 25°C, –40°C < TA < 85°C; ±1 dB PIN = –30 to +6dBm 5581fb For more information www.linear.com/LT5581 3 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Pin Functions Package Description
