Datasheet LTC5507 (Analog Devices) - 8
Description100kHz to 1GHz RF Power Detector
Pages / Page8 / 8 — RELATED PARTS. PART NUMBER DESCRIPTION. COMMENTS. RF Power Controllers. …
File Format / SizePDF / 134 Kb
RELATED PARTS. PART NUMBER DESCRIPTION. COMMENTS. RF Power Controllers. Other Related Parts
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS RF Power Controllers Other Related Parts
LTC5507
LTC1757A RF Power Controller Multiband GSM/DCS/GPRS Mobile Phones LTC1758 RF Power Controller Multiband GSM/DCS/GPRS Mobile Phones LTC1957 RF Power Controller Multiband GSM/DCS/GPRS Mobile Phones LTC4400 ThinSOT RF PA Controller Multiband GSM/DCS/GPRS Phones, 45dB Dynamic Range, 450kHz Loop BW LTC4401 ThinSOT RF PA Controller Multiband GSM/DCS/GPRS Phones, 45dB Dynamic Range, 250kHz Loop BW LTC4403 Multiband RF Power Controllers for EDGE/TDMA Supports EDGE/TDMA Applications LT5504 800MHz to 2.7GHz RF Measuring Receivers 80dB Dynamic Range, Temperature Compensated, 2.7V to 5.5V Supply LTC5505 300MHz to 3.5GHz RF Power Detector >40dB Dynamic Range, Temperature Compensated, 2.7V to 6V Supply LTC5508 300MHz to 7GHz RF Power Detector >40dB Dynamic Range, SC-70 Package
Other Related Parts
LT5500 1.8GHz to 2.7GHz, Receiver Front End Dual LNA gain Setting +13.5dB/–14dB at 2.5GHz, Double-Balanced Mixer, 1.8V to 5.25V Supply LT5502 400MHz Quadrature Demodulator with RSSI 1.8V to 5.25V Supply, 70MHz to 400MHz IF, 84dB Limiting Gain, 90dB RSSI Range LT5503 1.2GHz to 2.7GHz Direct IQ Modulator and 1.8V to 5.25V Supply, Four-Step RF Power Control, 120MHz Modulation Bandwidth Up Converting Mixer LT5506 500MHz Quadrature IF Demodulator with VGA 1.8V to 5.25V Supply, 40MHz to 500MHz IF, –4dB to 57dB Linear Power Gain LT5511 High Signal Level Upconverting Mixer 10MHz to 3000MHz RF Output Range, Integrated LO Buffer, 17dBm IIP3 LT5512 High Signal Level Down Converting Mixer DC-3GHz, 20dBm IIP3, Integrated LO Buffer 5507f LT/TP 0103 2K • PRINTED IN USA 8 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 2001
