Datasheet LTC5532 (Analog Devices) - 2
DescriptionPrecision 300MHz to 7GHz RF Detector with Gain and Offset Adjustment
Pages / Page16 / 2 — ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL …
File Format / SizePDF / 289 Kb
ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO ELECTRICAL CHARACTERISTICS The
LTC5532
W W W U ABSOLUTE AXI U RATI GS (Note 1)
VCC, VOUT, VM, VOS .. –0.3V to 6.5V Maximum Junction Temperature ... 125°C RFIN Voltage ..(VCC ± 1.5V) to 7V Storage Temperature Range .. – 65°C to 125°C RFIN Power (RMS) ... 12dBm Lead Temperature (Soldering, 10 sec) IVOUT .. 5mA SOT-23 Only ... 300°C Operating Temperature Range (Note 2) .. – 40°C to 85°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART TOP VIEW NUMBER NUMBER V 1 6 CC RFIN RF 6 V IN 1 CC V 2 7 5 OUT GND LTC5532EDC LTC5532ES6 GND 2 5 VOUT V 3 4 M VOS V 4 V OS 3 M DC6 PACKAGE DC6 PART MARKING S6 PACKAGE S6 PART MARKING 6-LEAD (2mm × 2mm) PLASTIC DFN 6-LEAD PLASTIC TSOT-23 TJMAX = 125°C, θJA = 85°C/W T LAFR JMAX = 125°C, θJA = 250°C/W LTAFS EXPOSED PAD (PIN 7) IS GND, MUST BE SOLDERED TO PCB Consult LTC Marketing for parts specified with wider operating temperature ranges.
C. VCC = 3.6V, RF Input Signal is Off, RA = RB = 1k, VOS = 0V unless otherwise noted (Note 2). PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC Operating Voltage ● 2.7 6 V IVCC Operating Current IVOUT = 0mA ● 0.5 0.7 mA VOUT VOL (No RF Input) RLOAD = 2k, VOS = 0V ● 85 100 to 140 155 mV VOUT Output Current VOUT = 1.75V, VCC = 2.7V, ∆VOUT < 10mV ● 2 4 mA VOUT Bandwidth CLOAD = 33pF, RLOAD = 2k (Note 4) 2 MHz VOUT Load Capacitance (Note 6) ● 33 pF VOUT Slew Rate VRFIN = 1V Step, CLOAD = 33pF, Total RLOAD = 2k (Note 3) 3 V/µs VOUT Noise VCC = 3V, Noise BW = 1.5MHz, 50Ω RF Input Termination, 1 mVP-P 50Ω AC Output Termination VOS Voltage Range ● 0 1 V VOS Input Current VOS = 1V ● –0.5 0.5 µA VM Voltage Range ● 0 VCC -1. 8 V VM Input Current VM = 3.6V ● –0.5 0.5 µA RFIN Input Frequency Range (Note 7) 300 to 7000 MHz RFIN Input Power Range RF Frequency = 300MHz to 7GHz (Note 5, 6) VCC = 2.7V to 6V –32 to 10 dBm RFIN AC Input Resistance F = 1000MHz, Pin = –25dBm 220 Ω RFIN Input Shunt Capacitance F = 1000MHz, Pin = –25dBm 0.65 pF
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
Bandwidth is calculated based on the 10% to 90% rise time of a device may be impaired. equation: BW = 0.35/rise time.
Note 2:
Specifications over the –40°C to 85°C operating temperature
Note 5:
RF performance is tested at 1800MHz range are assured by design, characterization and correlation with
Note 6:
Guaranteed by design. statistical process controls.
Note 7:
Higher frequency operation is achievable with reduced
Note 3:
The rise time at VOUT is measured between 1.3V and 2.3V. performance. Consult factory for more information. 5532f 2
