Datasheet LTC5564 (Analog Devices)
DescriptionUltraFast 7ns Response Time 15GHz RF Power Detector with Comparator
Pages / Page16 / 1 — FEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. Demo Board …
File Format / SizePDF / 475 Kb
FEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. Demo Board Schematic Optimized for 15GHz. VOUT vs Input Power 2.7GHz
Datasheet LTC5564 Analog Devices
LTC5564 UltraFast™ 7ns Response Time 15GHz RF Power Detector with Comparator
FEATURES DESCRIPTION
n Temperature Compensated Schottky RF Peak Detector The LTC®5564 is a precision, RF power detector for ap- n Wide Input Frequency Range: 600MHz to 15GHz† plications in the 600MHz to 15GHz frequency range. The n Wide Input Power Range: –24dBm to 16dBm LTC5564 operates with input power levels from –24dBm n 7ns Typical Response Time to 16dBm. n 75MHz Demodulation Bandwidth A temperature compensated Schottky diode peak detector, n Programmable Gain Settings for Improved Sensitivity gain-selectable operational amplifier, and fast comparator n Adjustable Amplifier Output Offset Voltage are combined in a small 16-lead 3mm × 3mm QFN package. n High Speed Comparator with Latch Enable: 9ns Typical Response Time The RF input signal is peak detected and then sensed by n 16-Lead 3mm × 3mm QFN Package both a comparator and amplifier. The comparator provides n a 9ns response time to input levels exceeding V Temperature Range: –40°C to 125°C REF along with a latch enable/disable function. The gain selectable
operational amplifier provides a 350V/µs slew rate and n 75MHz of demodulation bandwidth to the analog output. RF Signal Presence Detectors for: 802.11a, 802.11b, 802.11g, 802.15, Optical Data Links, Wireless Data VOUTADJ and VREF pins allow for the adjustment of VOUT Modems, Wireless and Cable Infrastructure offset and VCOMP switch point voltages, respectively. n 5.8GHz ISM Band Radios L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks and n UltraFast is a trademark of Linear Technology Corporation. All other trademarks are the property MMDS Microwave Links of their respective owners. n PA Power Supply Envelope Tracking Control †Higher frequency operation is achievable with reduced performance. Consult the factory for more information. n Fast Alarm n Envelope Detector n Ultra-Wideband Radio n Radar Detector
TYPICAL APPLICATION Demo Board Schematic Optimized for 15GHz
VCC
VREF 3400 1000pF 10pF 100pF VCOMP 3200 VCC = 5V 3000 TA = 25°C 2800 17 16 15 14 13 15GHz VCC 2600 GAIN8 RFIN 2.2pF NC VCCRF VREF VCOMP 2400 1 12 2200 RFIN VCCA 2000 GAIN4 0.5pF 10pF 1000pF 2 11 1800 NC VCCP 1600 LTC5564 3 68Ω 1400 10 GND V V OUT OUT 1200 GAIN1 OUTPUT VOLTAGE (mV) 100pF 1000 4 9 GND NC 800 V OUT 600 GAIN2 LEN VOUTADJ G0 G1 400 200 5 6 7 8 LEN 0 G1 –24 –20 –16 –12 –8 –4 0 4 8 12 16 V G0 OUTADJ RFIN POWER (dBm) 10k 10k 10k 5564 TA01b 5564 F05 5564fc For more information www.linear.com/LTC5564 1 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Applications Information Revision History Typical Application Related Parts
