Datasheet LTC5583 (Analog Devices) - 2
DescriptionMatched Dual-Channel 6GHz RMS Power Detector
Pages / Page28 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC5583
Supply Voltage ...3.8V TOP VIEW Enable Voltage ...–0.3V to V A A A CC + 0.3V + – TA CCN IN IN RP1 FL ENV V VOS Voltage ..–0.3V to VCC + 0.3V 24 23 22 21 20 19 INV Voltage ... –0.3V to 3.6V DECA 1 18 VOA Input Signal Power (Single-Ended, 50Ω) ...18dBm VCCA 2 17 RT1 Input Signal Power (Differential, 50Ω) ...24dBm VCCR 3 25 16 VODF T EN 4 GND 15 V JMAX .. 125°C OS Operating Temperature Range ... –40°C to 85°C VCCB 5 14 RT2 DECB 6 13 V Storage Temperature Range .. –65°C to 125°C OB 7 8 9 10 11 12 B B + – TB IN IN RP2 FL INV ENVB UF PACKAGE 24-LEAD (4mm s 4mm) PLASTIC QFN TJMAX = 125°C, θJA = 37°C/W EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC5583IUF#PBF LTC5583IUF#TRPBF 5583 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 5583fa 2
