Datasheet MCP1804 (Microchip)
Manufacturer | Microchip |
Description | 150 mA, 28V LDO Regulator With Shutdown |
Pages / Page | 36 / 1 — MCP1804. 150 mA, 28V LDO Regulator With Shutdown. Features:. … |
Revision | 10-29-2013 |
File Format / Size | PDF / 2.3 Mb |
MCP1804. 150 mA, 28V LDO Regulator With Shutdown. Features:. Description:. Applications:. Package Types. SOT-89-3. SOT-223-3
MCP1804 150 mA, 28V LDO Regulator With Shutdown Features: Description:
• 150 mA Output Current The MCP1804 is a family of CMOS low dropout (LDO) • Low Dropout Voltage, 260 mV Typical @ 20 mA, voltage regulators that can deliver up to 150 mA of V current while consuming only 50 µA of quiescent R = 3.3V • 50 µA Typical Quiescent Current current (typical, 1.8V VOUT 5.0V). The input operating range is specified from 2.0V to 28.0V. • 0.01 µA Typical Shutdown Current • Input Operating Voltage Range: 2.0V to 28.0V The MCP1804 is capable of delivering 100 mA with only 1300 mV (typical) of input to output voltage • Standard Output Voltage Options differential (V (1.8V, 2.5V, 3.0V, 3.3V, 5.0V, 10.0V, 12.0V) OUT = 3.3V). The output voltage tolerance of the MCP1804 at +25°C is a maximum of ±2%. Line • Output Voltage Accuracy: ±2% regulation is ±0.15% typical at +25°C. • Output Voltages from 1.8V to 18.0V in 0.1V The LDO input and output are stable with 0.1 µF of Increments are Available upon Request input and output capacitance. Ceramic, tantalum or • Stable with Ceramic Output Capacitors aluminum electrolytic capacitors can all be used for • Current Limit Protection with Current Foldback input and output. Overcurrent limit with current foldback • Shutdown Pin to 40 mA (typical) provides short circuit protection. • High PSRR: 50 dB Typical @ 1 kHz A shutdown (SHDN) function allows the output to be enabled or disabled. When disabled, the MCP1804
Applications:
draws only 0.01 µA of current (typical). Package options include the 3-lead SOT-89, 3-lead • Cordless Phones, Wireless Communications SOT-223, 5-lead SOT-23 and 5-lead SOT-89. • PDAs, Notebook and Netbook Computers • Digita l Cameras
Package Types
• Microcontroller Power
SOT-89-3 SOT-223-3
• Car Audio and Navigation Systems • Home Appliances
Related Literature:
(Top View) (Top View) • AN765, “Using Microchip’s Micropower LDOs” (DS00765), Microchip Technology Inc., ©2002 • AN766, “Pin-Compatible CMOS Upgrades to 1 2 3 1 2 3 BiPolar LDOs” (DS00766), Microchip Technology VOUT GND VIN V GND Inc., ©2002 OUT VIN • AN792, “A Method to Determine How Much Power a SOT23 Can Dissipate in an Application”
SOT-23-5 SOT-89-5
(DS00792), Microchip Technology Inc., ©2001 V V OUT SHDN IN NC 5 4 5 4 (Top View) 1 2 3 1 2 3 V GND V IN NC OUT GND SHDN 2009-2013 Microchip Technology Inc. DS20002200D-page 1 Document Outline Features Applications Related Literature Description Package Types Functional Block Diagram Typical Application Circuit 1.0 Electrical Characteristics Absolute Maximum Ratings 2.0 Typical Performance Curves FIGURE 2-1: Output Voltage vs. Output Current. FIGURE 2-2: Output Voltage vs. Output Current. FIGURE 2-3: Output Voltage vs. Output Current. FIGURE 2-4: Output Voltage vs. Output Current. FIGURE 2-5: Output Voltage vs. Output Current. FIGURE 2-6: Output Voltage vs. Output Current. FIGURE 2-7: Output Voltage vs. Input Voltage. FIGURE 2-8: Output Voltage vs. Input Voltage. FIGURE 2-9: Output Voltage vs. Input Voltage. FIGURE 2-10: Output Voltage vs. Input Voltage. FIGURE 2-11: Output Voltage vs. Input Voltage. FIGURE 2-12: Output Voltage vs. Input Voltage. FIGURE 2-13: Dropout Voltage vs. Load Current. FIGURE 2-14: Dropout Voltage vs. Load Current. FIGURE 2-15: Dropout Voltage vs. Load Current. FIGURE 2-16: Supply Current vs. Input Voltage. FIGURE 2-17: Supply Current vs. Input Voltage. FIGURE 2-18: Supply Current vs. Input Voltage. FIGURE 2-19: Supply Current vs. Input Voltage. FIGURE 2-20: Supply Current vs. Input Voltage. FIGURE 2-21: Supply Current vs. Input Voltage. FIGURE 2-22: Output Voltage vs. Ambient Temperature. FIGURE 2-23: Output Voltage vs. Ambient Temperature. FIGURE 2-24: Output Voltage vs. Ambient Temperature. FIGURE 2-25: Dynamic Line Response. FIGURE 2-26: Dynamic Line Response. FIGURE 2-27: Dynamic Line Response. FIGURE 2-28: Dynamic Line Response. FIGURE 2-29: Dynamic Line Response. FIGURE 2-30: Dynamic Line Response. FIGURE 2-31: Dynamic Load Response. FIGURE 2-32: Dynamic Load Response. FIGURE 2-33: Dynamic Load Response. FIGURE 2-34: Start-up Response. FIGURE 2-35: Start-up Response. FIGURE 2-36: Start-up Response. FIGURE 2-37: Start-up Response. FIGURE 2-38: Start-up Response. FIGURE 2-39: Start-up Response. FIGURE 2-40: SHDN Response. FIGURE 2-41: SHDN Response. FIGURE 2-42: SHDN Response. FIGURE 2-43: SHDN Response. FIGURE 2-44: SHDN Response. FIGURE 2-45: SHDN Response. FIGURE 2-46: PSRR 3.3V @ 1 mA. FIGURE 2-47: PSRR 5.0V @ 1 mA. FIGURE 2-48: PSRR 12.0V @ 1 mA. FIGURE 2-49: PSRR 3.3V @ 30 mA. FIGURE 2-50: PSRR 5.0V @ 30 mA. FIGURE 2-51: PSRR 12V @ 30 mA. FIGURE 2-52: Ground Current vs. Output Current. FIGURE 2-53: Ground Current vs. Output Current. FIGURE 2-54: Ground Current vs. Output Current. FIGURE 2-55: Output Noise vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: MCP1804 Pin Function Table 3.1 Unregulated Input Voltage (VIN) 3.2 Ground Terminal (GND) 3.3 Shutdown Input (SHDN) 3.4 Regulated Output Voltage (VOUT) 3.5 No Connect (NC) 4.0 Detailed Description 4.1 Output Regulation 4.2 Overcurrent 4.3 Shutdown 4.4 Output Capacitor 4.5 Input Capacitor 4.6 Thermal Shutdown FIGURE 4-1: Block Diagram. 5.0 Functional Description 5.1 Input 5.2 Output 6.0 Application Circuits and Issues 6.1 Typical Application FIGURE 6-1: Typical Application Circuit. 6.1.1 Application Input Conditions 6.2 Power Calculations 6.2.1 Power Dissipation 6.3 Voltage Regulator 6.3.1 Power Dissipation Example 6.3.1.1 Device Junction Temperature Rise 6.3.1.2 Junction Temperature Estimate 6.4 Voltage Reference FIGURE 6-2: Using the MCP1804 as a Voltage Reference. 6.5 Pulsed Load Applications 7.0 Packaging Information 7.1 Package Marking Information Appendix A: Revision History Product Identification System Trademarks Worldwide Sales and Service
