Datasheet ISL28130, ISL28230, ISL28430 (Intersil) - 6
ManufacturerIntersil
DescriptionSingle, Dual, and Quad Micropower, Low Drift, RRIO Operational Amplifiers
Pages / Page19 / 6 — ISL28130,. ISL28230,. ISL28430. Electrical. Specifications. V+. =. 5V,. …
Revision2017-11-07
ISL28130,. ISL28230,. ISL28430. Electrical. Specifications. V+. =. 5V,. V-. =. 0V,. VCM. =. 2.5V,. TA. =. +25°C,. RL. =. 10kΩ,. unless. otherwise. specified
ISL28130, ISL28230, ISL28430 Electrical Specifications V+ = 5V, V- = 0V, VCM = 2.5V, TA = +25°C, RL = 10kΩ, unless otherwise specified
ISL28130, ISL28230, ISL28430 Electrical Specifications V+ = 5V, V- = 0V, VCM = 2.5V, TA = +25°C, RL = 10kΩ, unless otherwise specified. Boldface limits apply over the entire operating temperature range. (Continued) MIN MAX PARAMETER DESCRIPTION CONDITIONS (Note 10) TYP (Note 10) UNIT AOL Open Loop Gain RL = 1MΩ 150 dB V+ Supply Voltage Guaranteed by VOS 1.8 5.5 V IS Supply Current, Per Amplifier RL = OPEN 20 25 µA 35 µA ISC+ Output Source Short Circuit Current RL = Short V- 15 mA ISC- Output Sink Short Circuit Current RL = Short V+ -15 mA AC SPECIFICATIONS GBWP Gain Bandwidth Product AV = 100, RF = 100kΩRG = 1kΩ, 400 kHz RL = 10kΩto VCM eN VP-P Peak-to-Peak Input Noise Voltage f = 0.01Hz to 10Hz 1.1 µVP-P eN Input Noise Voltage Density f = 1kHz 65 nV/(Hz) iN Input Noise Current Density f = 1kHz 72 fA/(Hz) f = 10Hz 80 fA/(Hz) Cin Differential Input Capacitance f = 1MHz 1.6 pF Common Mode Input Capacitance 1.12 pF TRANSIENT RESPONSE SR Positive Slew Rate VOUT = 1V to 4V, RL = 10kΩ 0.2 V/µs Negative Slew Rate 0.1 V/µs tr, tf, Small Signal Rise Time, tr 10% to 90% AV = +1, VOUT = 0.1VP-P RF = 0Ω, 1.1 µs RL = 10kΩ,CL = 1.2pF Fall Time, tf 10% to 90% 1.1 µs tr, tf Large Signal Rise Time, tr 10% to 90% AV = +1, VOUT = 2VP-P RF = 0Ω, 20 µs RL = 10kΩ, CL = 1.2pF Fall Time, tf 10% to 90% 30 µs ts Settling Time to 0.1%, 2VP-P Step AV = +1, RF = 0Ω,RL = 10kΩ, 35 µs CL = 1.2pF trecover Output Overload Recovery Time, Recovery to AV = +2, RF = 10kΩ, RL = Open 10.5 µs 90% of Output Saturation CL = 3.7pF NOTE: 10. Compliance to datasheet limits is assured by one or more methods: production test, characterization and/or design. FN7623 Rev 7.00 Page 6 of 19 February 13, 2014
