Datasheet ADXL1001, ADXL1002 (Analog Devices) - 6
DescriptionLow Noise, High Frequency +/-50g MEMS Accelerometer
Pages / Page14 / 6 — ADXL1001/ADXL1002. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. …
File Format / SizePDF / 763 Kb
ADXL1001/ADXL1002. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 10000. B) d (. 1000. UDE. ADXL1001. ADXL1002. 100. D AM E. ISE PSD. O N. –10
ADXL1001/ADXL1002 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 10000 B) d ( 1000 UDE ADXL1001 ADXL1002 100 D AM E ISE PSD O N –10
ADXL1001/ADXL1002 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 15 10000 10 B) d ( 1000 z) UDE H IT 5 /√ ADXL1001 L g P ADXL1002 100 D AM E 0 IZ ISE PSD AL O N RM 10 NO –5 –10 1 100 1k 10k 100k
004
0.01 0.1 1 10
007
FREQUENCY (Hz) FREQUENCY (Hz)
15431- 15431- Figure 4. Frequency Response of ADXL1001/ADXL1002, High Frequency Figure 7. ADXL1001/ADXL1002 Noise Power Spectral Density (Noise PSD) (>5 kHz) Vibration Response; a Laser Vibrometer Controller Referencing the Below 10 Hz ADXL1002 Package Used for Accuracy
100 100 90 90 80 80 70 70 60 DEVICE 1 60 DEVICE 1 DEVICE 2 DEVICE 2 50 ) DEVICE 3 ) 50 DEVICE 3 /√Hz 40 /√Hz g 40 g 30 30 ISE PSD ISE PSD O O N 20 N 20 10 10 100 1k 10k 100k
005
100 1k 10k 100k
008
FREQUENCY (Hz)
15431-
FREQUENCY (Hz)
15431- Figure 5. ADXL1001 Noise Power Spectral Density (PSD) vs. Frequency Figure 8. ADXL1002 Noise Power Spectral Density (PSD)
5 5 3 3 ) ) 1 1 Y (% Y (% T T IVI IVI T T SI SI –1 –1 SEN SEN –3 –3 –5 –5 –40 –10 20 50 80 110
006
–40 –20 0 20 40 60 80 100 120
009
TEMPERATURE (°C)
15431-
TEMPERATURE (°C)
15431- Figure 6. ADXL1001 Sensitivity vs. Temperature Figure 9. ADXL1002 Sensitivity vs. Temperature Rev. 0 | Page 6 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measurement Mode Standby BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
