Datasheet 1N5711, 1N5712, 5082-2300, 5082-2800, 5082-2900 (Avago Technologies)
ManufacturerAvago Technologies
DescriptionSchottky Barrier Diodes for General Purpose Applications
Pages / Page6 / 1 — Schottky Barrier Diodes for General Purpose Applications. 1N5711 1N5712 …
File Format / SizePDF / 58 Kb
Schottky Barrier Diodes for General Purpose Applications. 1N5711 1N5712 5082-2300 Series 5082-2800 Series 5082-2900
Datasheet 1N5711, 1N5712, 5082-2300, 5082-2800, 5082-2900 Avago Technologies
Technical Data
1N5711 1N5712 5082-2300 Series 5082-2800 Series 5082-2900 Features
The 5082-2835 is a passivated
Outline 15 • Low Turn-On Voltage
Schottky diode in a low cost glass As Low as 0.34 V at 1 mA package. It is optimized for low
0.41 (.016) 0.36 (.014) • Pico Second Switching Speed
turn-on voltage. The 5082-2835 is particularly well suited for the
• High Breakdown Voltage
UHF mixing needs of the CATV Up to 70 V
25.4 (1.00)
marketplace.
MIN. • Matched Characteristics 1.93 (.076) Available 1.73 (.068)
The 5082-2300 Series and 5082-2900 devices are unpas-
Description/Applications
sivated Schottky diodes in a glass The 1N5711, 1N5712, 5082-2800/ package. These diodes have
4.32 (.170) 3.81 (.150)
10/11 are passivated Schottky extremely low 1/f noise and are
CATHODE
barrier diodes which use a ideal for low noise mixing, and patented “guard ring” design to high sensitivity detecting. They achieve a high breakdown are particularly well suited for use voltage. Packaged in a low cost in Doppler or narrow band video
25.4 (1.00)
glass package, they are well suited receivers.
MIN.
for high level detecting, mixing, switching, gating, log or A-D converting, video detecting,
DIMENSIONS IN MILLIMETERS AND (INCHES).
frequency discriminating, sampling, and wave shaping.
Maximum Ratings
Junction Operating and Storage Temperature Range 5082-2303, -2900 ... -60°C to +100°C 1N5711, 1N5712, 5082-2800/10/11 .. -65°C to +200°C 5082-2835 .. -60°C to +150°C DC Power Dissipation (Measured in an infinite heat sink at T = 25°C) CASE Derate linearly to zero at maximum rated temperature 5082-2303, -2900 .. 100 mW 1N5711, 1N5712, 5082-2800/10/11 ... 250 mW 5082-2835 ... 150 mW Peak Inverse Voltage ... VBR Document Outline 1N5711 Features Description/Applications Maximum Ratings Outline 15 Package Characteristics Electrical Specifications Matched Pairs and Quads SPICE Parameters Typical Parameters Diode Package Marking
