Datasheet ADXL363 (Analog Devices) - 8
DescriptionMicropower 3-Sensor Combination Including Acceleration and Temperature
Pages / Page49 / 8 — Data Sheet. ADXL363. ABSOLUTE MAXIMUM RATINGS Table 5. RECOMMENDED …
RevisionA
Data Sheet. ADXL363. ABSOLUTE MAXIMUM RATINGS Table 5. RECOMMENDED SOLDERING PROFILE. Parameter. Rating. CRITICAL ZONE. TL TO TP
Data Sheet ADXL363 ABSOLUTE MAXIMUM RATINGS Table 5 RECOMMENDED SOLDERING PROFILE Parameter Rating CRITICAL ZONE TL TO TP
link to page 8 link to page 8
Data Sheet ADXL363 ABSOLUTE MAXIMUM RATINGS Table 5. RECOMMENDED SOLDERING PROFILE Parameter Rating
Figure 2 and Table 7 provide details about the recommended Acceleration (Any Axis, Unpowered) 5000 g soldering profile. Acceleration (Any Axis, Powered) 5000 g
CRITICAL ZONE
V
t
S −0.3 V to +3.6 V
P TL TO TP TP
VDD I/O −0.3 V to +3.6 V
RAMP-UP
All Other Pins −0.3 V to VS
E TL T tL
Output Short-Circuit Duration Indefinite
UR SMAX T
(Any Pin to Ground)
RA TSMIN
ESD, Human Body Model (HBM) 2000 V
EMPE
Short Term Maximum Temperature
T tS PREHEAT RAMP-DOWN
Four Hours 150°C One Minute 260°C 002 Temperature Range (Powered) −50°C to +150°C
t25°C TO PEAK TIME
1719- 1 Temperature Range (Storage) −50°C to +150°C Figure 2. Recommended Soldering Profile Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Table 7. Recommended Soldering Profile
rating only; functional operation of the device at these or any
Condition
other conditions above those indicated in the operational
Profile Feature Sn63/Pb37 Pb-Free
section of this specification is not implied. Exposure to absolute Average Ramp Rate (TL to TP) 3°C/sec max 3°C/sec max maximum rating conditions for extended periods may affect Preheat Minimum Temperature (T device reliability. SMIN) 100°C 150°C Maximum Temperature (TSMAX) 150°C 200°C
THERMAL RESISTANCE
Time (TSMIN to TSMAX)(tS) 60 sec to 120 sec 60 sec to 180 sec TSMAX to TL Ramp-Up Rate 3°C/sec max 3°C/sec max
Table 6. Package Characteristics
Time Maintained Above
Package Type θJA θJC Device Weight
Liquidous (TL) 16-Terminal LGA 150°C/W 85°C/W 18 mg Liquidous Temperature (TL) 183°C 217°C Time (tL) 60 sec to 150 sec 60 sec to 150 sec Peak Temperature (TP) 240 + 0/−5°C 260 + 0/−5°C Time Within 5°C of Actual 10 sec to 30 sec 20 sec to 40 sec Peak Temperature (tP) Ramp-Down Rate 6°C/sec max 6°C/sec max Time (t25°C) to Peak 6 minutes max 8 minutes max Temperature
ESD CAUTION
Rev. 0 | Page 7 of 48 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications ADXL363 Specifications Accelerometer Specifications Temperature Sensor Specifications 12-Bit ADC Specifications Absolute Maximum Ratings Thermal Resistance Recommended Soldering Profile ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Mechanical Device Operation Operating Modes Measurement Mode Wake-Up Mode Standby Selectable Measurement Ranges Selectable Output Data Rates Antialiasing Power/Noise Tradeoff Free Fall Detection ADC Analog Inputs Digital Output Temperature Sensor Power Savings Features Ultralow Power Consumption in All Modes, Operating All Sensors Motion Detection Activity Detection Referenced and Absolute Configurations Fewer False Positives Inactivity Detection Linking Activity and Inactivity Detection Default Mode Linked Mode Loop Mode Autosleep Using the Awake Bit FIFO System Level Power Savings Data Recording/Event Context Communications SPI Instructions Bus Keepers MSB Registers Additional Features External Clock Synchronized Data Sampling Self Test User Register Protection Serial Communications SPI Commands Read and Write Register Commands Read FIFO Command Multibyte Transfers Register Read/Write Auto-Increment Invalid Addresses and Address Folding Latency Restrictions Invalid Commands Register Map Register Details Device ID Registers Silicon Revision ID Register X-Axis Data (8 MSB) Register Y-Axis Data (8 MSB) Register Z-Axis Data (8 MSB) Register Status Register FIFO Entries Registers X-Axis Data Registers Y-Axis Data Registers Z-Axis Data Registers Temperature Data Registers ADC Data Registers Soft Reset Register Activity Threshold Registers Activity Time Register Inactivity Threshold Registers Inactivity Time Registers Activity/Inactivity Control Register FIFO Control Register FIFO Samples Register INT1/INT2 Function Map Registers Filter Control Register Power Control Register Self Test Register Applications Information Application Examples Device Configuration Autonomous Motion Switch Startup Routine Using External Timing Using an External Clock Using Synchronized Data Sampling How to Set Up Synchronized Data Sampling Power Power Supply Decoupling Power Supply Requirements FIFO Modes FIFO Disabled Oldest Saved Mode Stream Mode Triggered Mode FIFO Configuration FIFO Interrupts Retrieving Data from FIFO Interrupts Interrupt Pins Alternate Functions of Interrupt Pins Activity and Inactivity Interrupts Data Ready Interrupt Using FIFO Interrupts FIFO Watermark FIFO Ready Overrun Using Self Test Operation at Voltages Other Than 2.0 V Mechanical Considerations for Mounting Axes of Acceleration Sensitivity Layout and Design Recommendations Outline Dimensions Ordering Guide
