Datasheet ADXL377 (Analog Devices)
DescriptionSmall, Low Power, 3-Axis ±200 g Accelerometer
Pages / Page13 / 1 — Smal , Low Power, 3-Axis. ±200 g. Accelerometer. Data Sheet. ADXL377. …
RevisionB
File Format / SizePDF / 317 Kb
Smal , Low Power, 3-Axis. ±200 g. Accelerometer. Data Sheet. ADXL377. FEATURES. GENERAL DESCRIPTION. 3-axis sensing
Datasheet ADXL377 Analog Devices, Revision: B
Smal , Low Power, 3-Axis ±200 g Accelerometer Data Sheet ADXL377 FEATURES GENERAL DESCRIPTION 3-axis sensing
The ADXL377 is a small, thin, low power, complete 3-axis
Small, low profile package
accelerometer with signal conditioned voltage outputs. The
3 mm × 3 mm × 1.45 mm LFCSP
ADXL377 measures acceleration resulting from motion, shock,
Low power: 300 µA (typical)
or vibration with a typical full-scale range of ±200 g.
Single-supply operation: 1.8 V to 3.6 V
The user selects the bandwidth of the accelerometer using
10,000 g shock survival
the C
Excellent temperature stability
X, CY, and CZ capacitors at the XOUT, YOUT, and ZOUT pins. Bandwidths can be selected to suit the application, with a range
Bandwidth adjustment with a single capacitor per axis
of 0.5 Hz to 1300 Hz for the x-axis and y-axis and a range of
RoHS/WEEE and lead-free compliant
0.5 Hz to 1000 Hz for the z-axis.
The ADXL377 is available in a smal , low profile, 3 mm × 3 mm ×
Concussion and head trauma detection
1.45 mm, 16-lead lead frame chip scale package (LFCSP_LQ).
High force event detection FUNCTIONAL BLOCK DIAGRAM +3V VS ADXL377 OUTPUT 32kΩ XOUT AC AMPLIFIERS AMPLIFIER CX C Y DC 32kΩ OUT DEMODULATOR 3-AXIS CY SENSOR Z 32kΩ OUT CZ GND ST
001 10765- Figure 1.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices f or its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012 Analog Devices, Inc. A ll rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Mechanical Sensor Performance Applications Information Power Supply Decoupling Setting the Bandwidth Using CX, CY, and CZ Self-Test Selecting Filter Characteristics: Noise/Bandwidth Trade-Off Axes of Acceleration Sensitivity Layout and Design Recommendations Outline Dimensions Ordering Guide
