Datasheet ADXL345 (Analog Devices) - 8
Description3-Axis, ±2 g/±4 g/±8 g/±16 g Digital Accelerometer
Pages / Page10 / 8 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12657
File Format / SizePDF / 249 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12657
Case outline X Terminal Terminal Terminal Terminal symbol number symbol number 1 VDD I/O 14 SCL/SCLK 2 GND 13 SDA/SDI/SDIO 3 RESERVED 12 SDO/ALT ADDRESS 4 GND 11 RESERVED 5 GND 10 NC 6 VS 9 INT2 7 C�S �� 8 INT1 FIGURE 2. Terminal connections. Case outline X Terminal Mnemonic Description number 1 VDD I/O Digital interface supply voltage 2 GND This pin must be connected to ground. 3 RESERVED Reserved. This pin must be connected to VS or left open. 4 GND This pin must be connected to ground. 5 GND This pin must be connected to ground. 6 VS Supply voltage 7 C�S �� Chip select 8 INT1 Interrupt 1 Output. 9 INT2 Interrupt 2 Output. 10 NC Not internally connected. 11 RESERVED Reserved. This pin must be connected to ground or left open. 12 SDO/ALT Serial data output (SPI 4-Wire)/Alternate I2C address select (I2C). ADDRESS 13 SDA/SDI/SDIO Serial data (I2C)/Serial data input (SPI 4-Wire)/Serial data input and output (SPI 3-Wire). 14 SCL/SCLK Serial Communications clock, SCL is the clock for I2C, and SCLK is the clock for SPI FIGURE 3. Terminal function.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12657
REV PAGE 8 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/12657 REV
