Datasheet ADIS16209 (Analog Devices) - 10
Description | High Accuracy, Dual-Axis Digital Inclinometer and Accelerometer |
Pages / Page | 22 / 10 — Data Sheet. ADIS16209. 3.5. VDD = 3.0V, 3.3V, 3.6V TEMP = –40°C, +25°C, … |
Revision | H |
File Format / Size | PDF / 523 Kb |
Data Sheet. ADIS16209. 3.5. VDD = 3.0V, 3.3V, 3.6V TEMP = –40°C, +25°C, +85°C. 3.0. TION. 2.5. LA U. rees). 2.0. Deg. OF P. R (. 1.5. RRO. 1.0
Data Sheet ADIS16209 30 3.5 VDD = 3.0V, 3.3V, 3.6V TEMP = –40°C, +25°C, +85°C ) 3.0 % 25 ( TION 2.5 20 LA U rees) 2.0 OP 15 Deg OF P R ( 1.5 GE RRO TA 10 E N 1.0 E C R E P 5 0.5 0 0 –0.50 –0.38 –0.26 –0.14 –0.02 0.10 0.22 0.34 0.46 0 10 20 30 40 50 60 70 80 90
013 015
SENSITIVITY ERROR (%) OFF-VERTICAL TILT (Degrees)
07096- 07096- Figure 13. Accelerometer Output Sensitivity Error Distribution Figure 15. Error vs. Off-Vertical Tilt, 25°C, 3.3 V
20 VDD = 3.0V, 3.3V, 3.6V 18 TEMP = –40°C, +25°C, +85°C ) % ( 16 TION 14 LA U 12 OP 10 OF P 8 GE TA 6 N E C R 4 E P 2 0 –6.0 –4.4 –2.8 –1.2 0.4 2.0 3.6 5.2
014
BIAS ERROR (mg )
07096- Figure 14. Accelerometer Output Bias Error Distribution Rev. F | Page 9 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS RECOMMENDED PAD GEOMETRY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC OPERATION OUTPUT DATA REGISTERS Accelerometers Horizontal Incline Angle Vertical Incline Angle Internal Temperature Power Supply Auxiliary ADC OPERATION CONTROL REGISTERS Internal Sample Rate Power Management Digital Filtering Digital I/O Lines Data-Ready I/O Indicator Self-Test General-Purpose I/O Auxiliary DAC Global Commands CALIBRATION REGISTERS ALARM REGISTERS Status APPLICATIONS INFORMATION POWER SUPPLY CONSIDERATIONS Power-On-Reset Function Transient Current from VDD Ramp Rate Filter Settling ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
