Datasheet ADIS16003 (Analog Devices)
DescriptionDual-Axis ±1.7 g Accelerometer with SPI Interface
Pages / Page17 / 1 — Dual-Axis ±1.7 g. Accelerometer. with SPI Interface. Data Sheet. …
RevisionB
File Format / SizePDF / 264 Kb
Dual-Axis ±1.7 g. Accelerometer. with SPI Interface. Data Sheet. ADIS16003. FEATURES. GENERAL DESCRIPTION. Dual-axis accelerometer
Datasheet ADIS16003 Analog Devices, Revision: B
Dual-Axis ±1.7 g Accelerometer with SPI Interface Data Sheet ADIS16003 FEATURES GENERAL DESCRIPTION Dual-axis accelerometer
The ADIS16003 is a low cost, low power, complete dual-axis
SPI digital output interface
accelerometer with an integrated serial peripheral interface
Internal temperature sensor
(SPI). An integrated temperature sensor is also available on the
Highly integrated; minimal external components
SPI interface. The ADIS16003 measures acceleration with a full-
Bandwidth externally selectable
scale range of ±1.7 g (minimum), and it can measure both dynamic
1 mg resolution at 60 Hz
acceleration (vibration) and static acceleration (gravity).
Externally controlled electrostatic self-test
The typical noise floor is 110 μg/√Hz, allowing signals below
3.0 V to 5.25 V single-supply operation
1 mg (60 Hz bandwidth) to be resolved.
Low power: <2 mA 3500 g shock survival
The bandwidth of the accelerometer is set with optional capaci-
7.2 mm × 7.2 mm × 3.7 mm package
tors CX and CY at the XFILT and YFILT pins. Selection of the two analog input channels is controlled via the serial interface.
An externally driven self-test pin (ST) allows the user to verify the accelerometer functionality.
Industrial vibration/motion sensing Platform stabilization
The ADIS16003 is available in a 7.2 mm × 7.2 mm × 3.7 mm,
Dual-axis tilt sensing
12-terminal LGA package.
Tracking, recording, and analysis devices Alarms and security devices FUNCTIONAL BLOCK DIAGRAM VCC SCLK DUAL-AXIS DIN SERIAL ±1.7g INTERFACE ACCELEROMETER DOUT CS CDC TCS TEMP SENSOR COM ST YFILT XFILT
1
CY CX
-00 63 64 05 Figure 1.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2005-2012 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS CIRCUIT AND TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ACCELEROMETER DATA FORMAT SELF-TEST SERIAL INTERFACE ACCELEROMETER SERIAL INTERFACE Accelerometer Control Register Power Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details TEMPERATURE SENSOR SERIAL INTERFACE Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH SELECTING FILTER CHARACTERISTICS:THE NOISE/BANDWIDTH TRADE-OFF APPLICATIONS INFORMATION DUAL-AXIS TILT SENSOR Converting Acceleration to Tilt SECOND LEVEL ASSEMBLY OUTLINE DIMENSIONS ORDERING GUIDE
