Datasheet ADXL213 (Analog Devices) - 2
DescriptionLow Cost ±1.2g Dual Axis Accelerometer
Pages / Page13 / 2 — ADXL213* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 218 Kb
ADXL213* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADXL213* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADXL213 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADXL213 Breakout Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all ADXL213 EngineerZone Discussions. • AN-0989: Transitioning from ADXL202 to ADXL213 or ADXL203
SAMPLE AND BUY
• AN-1057: Using an Accelerometer for Inclination Sensing Visit the product page to see pricing options. • AN-600: Embedding Temperature Information in the ADXL202's PWM Outputs
TECHNICAL SUPPORT
• AN-603: A Compact Algorithm Using the ADXL213 Duty Submit a technical question or find your regional support Cycle Output number. • AN-604: Using the ADXL202 Duty Cycle Output • AN-652: Considerations for Soldering Accelerometers in
DOCUMENT FEEDBACK
LCC-8 Packages onto Printed Circuit Boards Submit feedback for this data sheet. • AN-688: Phase and Frequency Response of iMEMS® Accelerometers and Gyros
Data Sheet
• ADXL213: Low Cost ±1.2 g Dual Axis Accelerometer Data Sheet
Document Outline REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PERFORMANCE APPLICATIONS POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX AND CY SELF TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USING THE ADXL213 WITH OPERATING VOLTAGES OTHER THAN 5 V USING THE ADXL213 AS A DUAL-AXIS TILT SENSOR Dual-Axis Tilt Sensor: Converting Acceleration to Tilt PIN CONFIGURATIONS AND FUNCTIONAL DESCRIPTIONS OUTLINE DIMENSIONS ESD CAUTION ORDERING GUIDE AUTOMOTIVE PRODUCTS
