Datasheet ADXL213 (Analog Devices) - 5
DescriptionLow Cost ±1.2g Dual Axis Accelerometer
Pages / Page13 / 5 — ADXL213. ABSOLUTE MAXIMUM RATINGS Table 2. ADXL213 Stress Ratings. Table …
RevisionA
File Format / SizePDF / 218 Kb
ADXL213. ABSOLUTE MAXIMUM RATINGS Table 2. ADXL213 Stress Ratings. Table 3. Package Characteristics. Parameter Rating
ADXL213 ABSOLUTE MAXIMUM RATINGS Table 2 ADXL213 Stress Ratings Table 3 Package Characteristics Parameter Rating
ADXL213 ABSOLUTE MAXIMUM RATINGS Table 2. ADXL213 Stress Ratings Table 3. Package Characteristics Parameter Rating Package Type θJA θJC Device Weight
Acceleration (Any Axis, Unpowered) 3,500 g 8-Lead CLCC 120°C/W 20°C/W <1.0 gram Acceleration (Any Axis, Powered) 3,500 g Drop Test (Concrete Surface) 1.2 m VS –0.3 V to +7.0 V All Other Pins (COM – 0.3 V) to (VS + 0.3 V) Output Short-Circuit Duration (Any Pin to Common) Indefinite Operating Temperature Range –55°C to +125°C Storage Temperature –65°C to +150°C Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
CRITICAL ZONE tP TL TO TP TP RAMP-UP TL T tL SMAX RATURE E TSMIN MP TE tS PREHEAT RAMP-DOWN
03757-0-002
t25°C TO PEAK TIME Condition Profile Feature Sn63/Pb37 Pb Free
Average Ramp Rate (TL to TP) 3°C/second max Preheat • Minimum Temperature (TSMIN) 100°C 150°C • Minimum Temperature (TSMAX) 150°C 200°C • Time (TSMIN to TSMAX) (tS) 60–120 seconds 60–150 seconds TSMAX to TL • Ramp-Up Rate 3°C/second Time Maintained above Liquidous (TL) • Liquidous Temperature (TL) 183°C 217°C • Time (tL) 60–150 seconds 60–150 seconds Peak Temperature (TP) 240°C +0°C/–5°C 260°C +0°C/–5°C Time within 5°C of Actual Peak Temperature (tP) 10–30 seconds 20–40 seconds Ramp-Down Rate 6°C/second max Time 25°C to Peak Temperature 6 minutes max 8 minutes max Figure 2. Recommended Soldering Profile Rev. A | Page 4 of 12 Document Outline REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PERFORMANCE APPLICATIONS POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX AND CY SELF TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USING THE ADXL213 WITH OPERATING VOLTAGES OTHER THAN 5 V USING THE ADXL213 AS A DUAL-AXIS TILT SENSOR Dual-Axis Tilt Sensor: Converting Acceleration to Tilt PIN CONFIGURATIONS AND FUNCTIONAL DESCRIPTIONS OUTLINE DIMENSIONS ESD CAUTION ORDERING GUIDE AUTOMOTIVE PRODUCTS
