Datasheet AD652 (Analog Devices) - 5
DescriptionMonolithic Synchronous Voltage-to-Frequency Converter
Pages / Page12 / 5 — STANDARD. 5962-93222. MICROCIRCUIT DRAWING
File Format / SizePDF / 109 Kb
STANDARD 5962-93222 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics. Conditions 1/ Test Symbol -55C  TA +125C Group A Device Limits Unit ±V subgroups type S = 15 V unless otherwise specified Min Max fCLOCK = 1 MHZ, % of Linearity error 2/ 3/ LE V 1,2,3 01 0.02 IN = .01 V; 1.0 V to 9.4 V FS in 1.05 V steps fCLOCK = 4 MHZ, V 0.05 IN = .01 V; 1.0 V to 9.4 V in 1.05 V steps fCLOCK = 1 MHZ, % of Gain error 2/ AE 1 01 1 V FS IN = .01 V, 9.4 V fCLOCK = 4 MHZ, 1.5 VIN = .01 V, 9.4 V Gain temperature fCLOCK = 1 MHZ, TCA 2,3 01 50 ppm/C coefficient VIN = .01 V, 9.4 V fCLOCK = 4 MHZ, 75 VIN = .01 V, 9.4 V Power supply rejection 3/ 12 V  VS  18 V, 1 0.01 PSRR 01 %/V ratio fCLOCK = 4 MHZ 2,3 0.04 Input offset voltage 4/ VIN = 0.1 V, 9.4 V, V 1 01 3 mV (transfer function, RTI) IO fCLOCK = 1 MHz, 4 MHZ Input offset voltage (RTI) TCV temperature coefficient IO fCLOCK = 1 MHZ 2,3 01 50 V/C Input resistor RIN 1 01 19.8 20.2 k Input resistor temperature TCRIN 2,3 01 100 ppm/C Op amp input bias 3/ IIB VIN = 0 V, inverting input 1 01 20 nA current 2,3 40 V IN = 0 V, 1,2,3 50 noninverting input Op amp input offset 3/ I current OS VIN = 0 V 1,2,3 01 70 nA Op amp input offset 3/ V voltage OS VIN = 0 V 1,2,3 01 3 mV See footnotes at end of table.
STANDARD
SIZE
5962-93222 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C 5 DSCC FORM 2234 APR 97
